silverbear
The Boy Who Never Grew Up
I really like the routing of the exhaust and how it ends up straight out the back, between the baskets and under the rack. Very cool!
SB
SB
I like that swivel. I wonder if Napa would have one. Think I'll see. Did you need to drill out the hole to make it bigger?
SB
The engine needs to be high in the frame because the cylinder slants back rather than straight up. If it sits too low, the cylinder will hit the seat post and the front of the engine will hit the down tube. It's just a matter of clearance. Get a wide pedal crank too. I have one and I think I'm still going to get pedal extensions too. It is a wide motor.
Jim
Why is the engine so high? Is it to clear the cranks? I have been thinking about this motor as well. I also thought about using 165 crank arms vs the typical 175cm. Not a lot of differnce but some
OK, got everything aligned and buttoned down tight, took her out for a test run and it feels like the chain is skipping some teeth on the sprocket at a regular interval. After stopping, noticed the chain is kinky....stiff link kinda kinky. Running the Q-matic on the HF with a 56t rear sprocket and a 415 chain. Would a #41 chain cure this problem? Anybody else ever expirience this? Any input would be greaty appreciated, thanks.
The MaxTorque clutch is sized for 41 chain.
I can't get 415 chain to even fit on mine
The build looks fantastic. In response to the scarecrow pedaling, all I can say is that rearmounting is the way to go. My motor is on a Trek 3700. When I was at the hardware store one day, a guy noticed my bike and the first thing he said was "Darn, aren't you supposed to put those motors on a crappy bike?". I told him I was glad I put it on a nice bike because it made the ride all the more enjoyable, and comfortable.Thanks man....that's what I was thinkin....off to buy 10' of #41.
Also, where did you get your 56 tooth sprocket?
I believe that sprocket came from Spooky Tooth....the 56 tooth on my other bike came with the EZM kit, but I enlarged the hole to bolt it on a freewheeling HD hub.
