f1gopedder
The brass bushing on my clutch came with spiral cut oil groves in it. For me this is my interpretation of how my wear is on it. My oil groves are still very nicely pronounced. These said oil groves basically only have so much depth to them. When my groves get a bit shallower then will replace my bushing. This is my take on it anyway.. ''Shrug''
The two needles one needle physically moves the carb slide up and down. This is your static idle adjustment. How high to have your motor idle at...
The other is a fuel mixture screw for the first 1/3 throttle or so. If you have any lag in your throttle response like it is not quick clean crisp, responsive. Then this screw can clean that up. Should be able to blip the throttle towards wot and have no lag in your response. Anywhere from 1 to 3 turns mebbe really depends on what idle jet you have in it from the factory. Can't tell you I don't live at sea level.. Betcha go 1 1/2 turn out and go from there?
Why are you messing with it is it not running right?
My carb is set for 6000 plus foot. A.S.L at about 1 1/2 turn out. In the heat of the summer I set it just a little leaner. In winter I go a tiny bit richer like 1/4 turn
All carbs come from the factory tuned for sea level for the most part.. You live at sea level?
well the only reason im messing with it is because it was at 1/2 turn out!!!! in the goped world... the engine would have been seized by now. So i put it at 1 1/2 turns out each needle to see if it performs better. But it was running great at 1/2 turn out so i guess well see what happens.
I just ordered an 11 tooth sprocket for the big boy and I was wondering how hard would it be to lengtthen the chain if need be? I think its #35 chain. And is an 11 tooth the biggest I can go on the front sprocket of the s6s? I saw they have a 12 tooth as well but im concerned about clearence issues.
