micargi rover gt build
Discussion in 'Stretch Cruiser & Chopper Motorized Bicycles' started by waw1220, May 27, 2014.
  1. waw1220
    waw1220 New Member
    May 27, 2014
    6
    i wish to put a flying hoarse 80cc 2 stroke on a micargi 26" rover gt can anyone please help and tell me what all is needed for this build.shft.
    #1 waw1220, May 27, 2014
  2. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,781
    The Rover is fine if you have 36 spoke wheels. The rag joint sprocket that comes with the kit will not fit the 60 spoke wheels like the ones in your pic.
  3. waw1220
    waw1220 New Member
    May 27, 2014
    6
    what about if i use a manic mechanic occ chopper sprocket adapter assemblyinstead of the stock sprocket mount that comes with the motor.shft.
  4. wheelbender6
    Sep 4, 2008
    3,781
    You should ask the seller if the Manic Mechanic will work with the 60 spoke wheels. There is just very little room for any bolts to fit between the spokes on that type of wheel.
  5. waw1220
    waw1220 New Member
    May 27, 2014
    6
    so id probly just benefit by replaceing the back rim witha standard 26" beach cruiser rim
  6. waw1220
    waw1220 New Member
    May 27, 2014
    6
    im actualy doing 2 of these so i think ill just pick up a couple standard rims to avoid any trouble.shft.
  7. waw1220
    waw1220 New Member
    May 27, 2014
    6
    do you think ill need the jnm vibration motor mounts for that frame
  8. kevyleven007
    kevyleven007 Active Member
    Sep 25, 2008
    1,178
    You are going to need custom front motor mounts and a custom tank. Stock will not work.
  9. waw1220
    waw1220 New Member
    May 27, 2014
    6
    the jnm vibration motor mounts or the heavy duty u bolt mounts wont work for this what about the extra wide gas tank mounts.trlrl.
  10. kevyleven007
    Sep 25, 2008
    1,178
    I don't know that stuff might work. I like the rover its longer and lower than a standard cruiser and the frame is really solid. That top tube is really wide so I don't know. You could probably make it work.
  11. Micargirovergt
    Micargirovergt New Member
    Jan 16, 2016
    19
    It's a bit difficult but well worth it you will need to change to a 36 spoke rim and you will need to get or make an extended motor mount I opted to purchase one
  12. JoeMetro
    JoeMetro Member
    May 4, 2014
    49
    As stated earlier, you'll need to switch out at least the rear wheel. Even the manic mechanic sprocket adapters won't work with that many spokes.
    I would highly advise avoiding the use of anything between your bike frame and motor mounts. The rubber won't do much, and it's much better to have a flush metal on metal contact. I'm not sure but to me It looks to me like you won't have much problem using a manic mechanic front motor mount and jimmying something for the rear mount.
    As for mounting the gas tank, I don't think extra wide mounts will do it. My bike (fito modena GT) also has a really large top tube. I just cut up a belt and drilled holes to make it work, along with foam mounting tape underneath the tank. It has a little wiggle to it but it gets the job done.
    #12 JoeMetro, Jan 24, 2016
  13. biknut
    biknut Active Member
    Sep 28, 2010
    6,355
  14. joshuabosseler90
    joshuabosseler90 New Member
    Sep 17, 2016
    What length are your triple tree forks?
  15. Tyler6357
    Tyler6357 Member
    Mar 15, 2012
    756
    Never use jnm vibration motor mounts, just don't do it.
