biknut
Bomb azz bike... Your tire choice is right on.... Not sure about the bars... Sorry
Thanks man.
Those are the stock bars turned up instead of down. I wasn't too wild about them at first either, but they're growing on me.
Did you get the arm bent to your satisfaction BN? There's always the Ridley arm and it's a direct replacement. That was my choice.
Yup, I know what you are saying. I am using the Sportsman's Flyer sprocket and adapter and the same KW engine mounts. The Ridley arm is a bolt on. Doesn't help now as far as the time spent but if you decide the arm looks too over worked it's a backup.
Just for ref: http://www.piratecycles1.com/rimocobebrar.html
Mine is the star. I had posted the Pirate link because they show the double D arm. I bought mine directly from Ridley. The contact info is in this thread: http://motorbicycling.com/showthread.php?t=39675
I see. Good to know and cool that you posted that. I'm certainly OK with being wrong as long as it gets put right. If anyone does a search in the future they are likely to find an answer. Bummer there's not a good / easy solution for everybody but at least you have a functional brake arm.
This bike has no pretention of being a racer. The motor is basically stock. The only difference is instead of an NT carb I installed a Speed carb, with the $12 air filter. From my experience that won't make it any faster, but it will idle better and have less 4 stroking. My muffler is what I call a modified stock exhaust. It's a stock header with a custom pipe made from a short length of Sportster exhaust pipe strategically cut for looks, with a stock flying horse baffle, sans the cat. This muffler is basically just like the one on the Atomic BB. That means it's not a performance pipe, but it should be very quiet, and work well enough to run 7000 rpm. I'm running a 36T sprocket. I haven't taken the time to calculate the top speed, but with these little 24" wheels I'm thinking it will be doing good to get 30 or 32 mph I hope.
I'll be happy if it runs smooth, and is dependable, like the flying horse motor in the Atomic BB.
That's looking awesome Bro!!![]()
Looks great. Really, looks great!
Right on, stealthy pedal is a stealthy ride![]()
You have built a very nice bike indeed! It looks fast just sitting still.
Very clean and well thought out.
The more I look at it, the more I really like your tire choice!
I know what you mean when you say the stock tires have a kind of 'clownish' look to them... If I ever build one of these for myself, I'm following your lead on tire choice.![]()
