Lost a part
Discussion in 'Motorized Bicycle General Discussion' started by Toothy, Apr 19, 2014.
  1. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    I have lost the small washer that goes in the throttle / cable needle assembly on my china engine. Not the black one that fits onto the needle but the silver one, i think it's called a "pac man" clip. I'm almost ready to take the bike out for the fist time and am pissed with myself. Where could I find another one or is there a way to make another? I'm sure the thickness of the washer it critical so the latter may not be possible.
    Any ideas.....thanks
  2. maniac57
    Oct 8, 2011
    4,486
    It is there to hold the needle from sliding up when the throttle slide moves down. Any washer that fits the slide can easily be used to replace the one you lost. The slot is for the cable to move in. Any washer can be used if you simply cut a small hole or slot for the cable.
    Keep in mind the needle clip needs to be held down solidly so be sure the hole in your replacement washer is smaller than the needle clip.
  3. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks! I'll try to make a new one.
  4. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    the hole in the washer is the critical part, if the hole in what you use is to big then the C-clip that is on the needle will slide through the hole in the washer and allow the needle to rise out of place, anything that is large enough around for the spring to press against and has a hole/slot small enough that the C-Clip cant get through it will work, if you have some tin snips you could make one out of a piece of a tin can lid or any other similar thickness flat steel.
    Map
  5. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    I lost one myself a while back (it's probably deep in the 'stuff' under my workbench).. I just used a dremel cutting wheel to make a new one out of a small washer. Hold it firmly, or you'll be making another before you're done the first replacement. ;)
  6. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks for all the great help. I ended up making one out of some thin aluminum I had. I still have to run the bike so I'll let you know if it worked!
