Looks like I need a new bike...
im sure you can work it out, i used an exhaust clamp, D clamp, with a car sway bar rubber in the original slot on the motor to fill the gap, got a steel plate, drilled a couple holes for the studs on the motor to bolt through the plate, then bolted that to the clamp, and clamp to the frame, with a bit of very solid rubber around the frame, think its off a conveyor belt, dont really need it, but i didnt want to damage frame, and its solid as.
Just remove the short front studs from the front ,and get the correct length hardened steel bolts and just bolt it on with the stock mount.
good luck, remember if you need a little more clearance up top you can swap your head around so the plug faces the other way, 10-12inch pounds of torque, iirc. You'll want to double check that, its late :p You can get away with a steel plate and a muffler clamp or two too, just a thought, gl.
