longest ride u have taken your motorized bicycle on
Discussion in 'Motorized Bicycle General Discussion' started by baadboy, Mar 20, 2011.
  1. fall_down_stand_up
    fall_down_stand_up New Member
    Apr 26, 2009
    555
    Re: longest ride u have taken your MB on
    I live in the country and on an average day I will drive around 15 to 20 miles a day round trip....
    John
  2. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    A friend and I rode to his Mothers house and then from there to the other side of the lake she lives on, where his grandmother lives. So between 50 and 60 miles round trip.
  3. masterx1234
    masterx1234 New Member
    May 7, 2009
    51
    i made a couple 40-50 mile trips, ran outta gas on one trip
  4. scotto-
    Jun 3, 2010
    6,527
    A couple months back I did 2 round trips that totaled 110 miles in 1 day. That's the most in one day that I can remember and I was actually a little sore the next day as I did it on a rigid bike.....no suspension on my cruisers.
    dnut
  5. Cogswelln
    Cogswelln New Member
    Dec 6, 2009
    208
    the furthest round trip for my trike 14 miles, for my regular mt bike it was 20 miles round trip. the difference from going to my cusins or the warf
  6. baadboy
    baadboy New Member
    Jul 28, 2010
    90
    this is the first trike post Ive seen but it looks like these little girl can do some mileage.shft.
  7. 210Don
    210Don New Member
    Feb 13, 2011
    15
    I've done about 34+- round-trip. My first trip, i didn't have a derailleur so i had a ton of chain slap and my tire would grab the chain and pull it off the sprocket, it was pretty dangerous. I installed the derailleur and the second trip was smooth. The only issue i have now is not being able to fully disengage the clutch as the carburetor on my china girl impacts with the clutch arm. i plan on bending it so it clears... any other suggestions on that?
  8. baadboy
    baadboy New Member
    Jul 28, 2010
    90
    got a pic that dont sound right 4 the clutch hitting the carb
  9. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    If your clutch arm is hitting the carb. before it clutches the engine you have either major wear on the flat surface of the clutch camshaft that pushes the bucking bar inward to disengage the clutch or the bucking bar itself is wore on one or both ends.
    I say pull the clutcharm/chain gear cover off and inspect the lower part of the camshaft to see if it has a groove wore in it where it contacts the bucking bar and if not then take th bucking bar out and look to see if the 8mm ball bearing that it rides against have dished out the center of the bar, if it has then go to the local Tractor supply or hardware store and get a bolt that is either 5/16 or 8mm in diameter and about 3 inches long so it has an area between the threads and the head of the bolt that is long enough so that with a hacksaw or other means of cutting it you can use a piece of the unthreaded section of that bolt to make you a new bucking bar by cutting a section out of it that is the same length or maybe even a few .001's langer than the original bar.
    I have done this on one of mine and it makes a better bucking bar than the ones that come in these engines in my opinion.
    One or both of these two things I discribed here are likely your problem/ or problems from my experience.
    If you need a clutch arm camshaft Piston Bikes has it here for $3 Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts
    They also have the new bucking bar for $4
    I dont understand the bucking bar costing $1 more that the camshaft which is machined to make verses the bucking bar just being a piece of junk round bar that isnt normally even cut true on the ends......... but anyway I say check these points and I'll bet you find your problem.
    Good luck, Peace
