I think ur right about the white wire Tom, if trying to run the light system directly off it. It will power a normal bicycle lamp but that is not good enough for these by far. If u use it to charge a battery tho, then run a decent incandecent lamp off the battery, things r much better, so long as ur night riding time is less than the battery's duration. I use a bridge rectifier (IIRC, I also used blocking diodes between the rectifier & battery) all made up with Schotky diodes, to charge a 6 volt, 4.5 A/h SLA battery & run a 26 watt 6 volt halogen lamp off it. It doesnt give motor cycle type light, but it gives ample for the small amounr of night riding I do. The good thing about this is I dont have to charge the battery so long as I do daytime riding, it charges constantly when the motor is running & the white wire simply doesnt put out enough current to cook a battery without a regulator. BTW KCVale, $75 for the light & battery, not even close to that much. The whole system didnt cost $30. The 4.5A/h SLA 6V battery cost $17 off the shelf at the local electronics outlet so buying online would be even less. The lamp shell is a small automotive driving light from an auto wreckers that I put the 6V 26W bulb in, & 6 diodes, so nowhere near $75. Problems with it dragging down the magneto, nil. My homemade CDI copes with it very well. I know that the white wire wont run the light or cope with a very run down battery. Like I said, I do limited night riding but I know that any night of the week I can switch on that 26 watt halogen light for half an hour to ride home & it wont drain the battery. In the morning I can start it without a problem & no performance loss while riding. To me thats worth the money it cost to set it up. I know its limitations & dont try to exceed them. Obviously using the light til the battery is low will cause magneto issues, but a 1/2 hour ride home using it & being able to see well enough definitely doesnt. Cheers
