Is this kit Good, Bad, or ugly?
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Staton has a good reputation for quality. I'm not a friction drive fan but there are a lot of them out there.
Good luck.
GearNut
5,104
11
San Diego, Kaliforgnia
Friction drives will not eat up rear tires if you choose the correct ones. Look for a tire with a flat tread profile and a tread pattern that is rather smooth, not knobby.
That said, it is true that a friction driven tire will not last quite as long as a chain or belt driven one.
GearNut
5,104
11
From what I have learned on this forum, friction drives last about the same time assuming that the chinagirl engine you get is a good one. The Tanaka, Mitsubishi and Subaru engines are definitely better built than the chinagirls and you are more apt to get a longer life and reliability from them without the gamble you have with a chinagirl.
Chinagirls have more brute power though.
Chinagirls are also alot cheaper to rebuild and have waaay more aftermarket support in regards to performance upgrades.
The_Aleman
2,653
That friction drive kit should last a long time. They are very simple and far better built than an out-of-the-box chinagirl.
As mentioned above, rear tire choice is very important. I recommend something like a CST C1218. Very durable, should play nice with a FD.
One thing tho: if you ride on wet roads a lot, you may not like a friction drive. They can slip.
GearNut
5,104
11
On flat ground it would travel the same once you are up to speed.
It will slip a bit under brisk acceleration or climbing a grade.
Water will act like a lubricant between the drive roller and the tire.
If it is slippery it will slip.
Albula vulpes
419
FL
A friction drive is more reliable than the 66cc inframe chinagirls. They run fine when wet until the roller wears down from excessive wear. Then they start to slip when wet. I would get the BMP(roadbug) friction kit over the staton, because you can change the roller with little effort after the roller wears down.
Ironhorse5.1
20
Norman, Oklahoma
The roller is heat treated and zinc plated. I'm not worried about it wearing out.
