Intake port piston location???
Discussion in 'Motorized Bicycle General Discussion' started by 577-Jersey, Jun 6, 2013.
  1. 577-Jersey
    577-Jersey New Member
    Mar 23, 2013
    293
    Hi guys,,
    I have an engine here with low power and it pings a bit when warm,,running 32:1 dino,,I noticed when i took the intake off and turn over the motor,,the top of the piston does not come down low enough for the fuel to get into the chamber,,it comes down to the top of the first ring but that's it,,my question is,, shouldn't it come down a little lower or should I trim the port out with a grinder so the fuel can get into the chamber better,,or are all of them this way???
    Thanks Tom
    Good times.....
  2. maniac57
    Oct 8, 2011
    4,486
    Be VERY careful changing the height of the ports, this controls timing on these engines and can lead to ruined motors. Most people simply grind a small "ramp" in the piston crown to improve flow. MUCH safer. I would counsel against messing with the port size unless you know exactly what you are doing. If you try the ramp. don't grind too far down into the ring lands. Leave a bit of untouched aluminum above the ring groove for strength.
    Search porting and high-performance engine mods. I've seen a thread here on this mod somewhere...
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,517
    48
    2-strokes send fuel to the bottom end first
  4. 577-Jersey
    Mar 23, 2013
    293
    And up through the transfer port correct,,I need to pull the jug tomorrow and see whats going on,,sounds like its constricted somewhere..
    Thanks Guys!!
  5. 577-Jersey
    Mar 23, 2013
    293
    I may try that also!!
    Thanks Maniac!
  6. maniac57
    Oct 8, 2011
    4,486
    I think the usual mod is to trim the piston skirt on the intake side and ramp the piston on the exhaust. (I'm heavily medicated tonight and cannot think straight)
  7. 577-Jersey
    Mar 23, 2013
    293
    I need to be medicated,,my sciatic nerve is so bad feels like a hot knife in my rear...
  8. maniac57
    Oct 8, 2011
    4,486
    Knees here...thank goodness for modern pharmaceuticals!
  9. 577-Jersey
    Mar 23, 2013
    293
    That and beer!
