yeah, it works great.
BUT mine came with 2 pins, one smaller one that worked on both chains, and one big one that'd work on, well, big chains.
i was at H.F. the other day, and all the ones they had had 2 pins, but both of them were the large ones. dunno why, maybe bad quality control in china?
you would need to grind the pin down a little to make it work. 10 seconds with a grinder, or a couple minutes with a file and your all set.
My favorite chain breaker
I spoke to a guy at a bike shop today and he told me to make sure that the bottom part of the engine (not the part with the piston) was oiled, or else the engine would be totally trashed. So, Is the bottom half of the engine oiled?
Sorry for all my questions, I just want to get this thing finished so that I can ride with peace of mind!
When you get ready to start the bike for the first time-
Turn on the gas, and wait for 30 seconds.
Push your "tickler button" otherwise known as a primer for 2 seconds.
Pull your choke lever UP about 3/4 of the way.
Pull in the clutch lever and pedal up to a good cruising speed.
Open your throttle just a tiny bit and let the clutch out, it should at least fire. Keep pedaling and work the throttle a LITTLE bit and see what happens.
If it won't even try to fire, get back to us.
If it does fire up, let it run at a slow cruise for a minute and push the choke lever back DOWN. Get back to us and let us know how it went after a good ride...
