Im Going Legal in PA
Horsepower - Wikipedia, the free encyclopedia
It's there - just waaay down the page & is where I realized my mistake heh
Pretty sure that w/a new dyno (or you can do it the hard way w/e the evil math), the BHP can be calcuated from the gear ratios you're after (inc wheel OD ofc). TBH I really need to look for a local dyno myself for similar reasons... but I been slackin' lol
Hi Indian Jim,
We ship all EZM kits to travel on level ground with a 200-pound rider at 30 MPH. It is impossible to have all kits have the exact top speed because of weight, wind, weather, elevation and terrain.
Although some of the EZM kits can reach speeds above 40 MPH [depending on conditions], it doesn't mean it will only travel at that speed. Just like cars that can travel at 150 MPH, you must control the speed with the throttle. In other words if your top speed limit is 25 MPH, then just keep the speed regulated with the throttle.
A few companies [4 stroke kits] set the final top speed by using radical ratios [25 X 1], and had to watch as several managed to run the motor above 9000 RPMs [or above] for long periods of time and make "scrap metal" from a great motor [Both Honda and HS motors were involved].
Here are the numbers you requested, however they will do little to help if your state insists on a motorbike with an exact top speed of 25 MPH.
The stock EZM kit with the HS 142 motor is shipped with a primary ratio of 2.76 X 1, and a secondary drive ratio of either 5.6 X 1 or 6 X 1. With the 56-tooth rear sprocket the final ratio is 15.456 X 1, and with the 60-tooth rear sprocket it is 16.56 X 1.
I will indicate RPM at 25 MPH on a 26" bike for both ratios..........
15.456 X 1 = 25.02 MPH @ 5000 RPMs
16.56 X 1 = 25.22 MPH @ 5400 RPMs.
The EZM primary ratios can be altered by a simple belt replacement........
Using an AX or 3VX series belt will deliver the following ratios......
2.62 X 1 primary X 5.6 secondary = 14.67 X 1 [25.04 MPH @ 4750 RPMs].
2.62 X 1 primary X 6 secondary = 15.72 X 1 [25.09 MPH @ 5100 RPMs].
2.935 X 1 primary X 5.6 secondary = 16.43 X 1 [25.1 MPH @ 5350 RPMs].
2.935 X 1 primary X 6 secondary = 17.61 X 1 [25.03 MPH @ 5700 RPMs].
If PA laws are similar to NC laws, I am sure the 49 CC 4 stroke will "fit" within the limits, as the term "Brake HP" would have little or no meaning. In one section of the NC law it states a 35 MPH limit, whereas in another section it states 30 MPH as the top speed.
I also know of many PA riders and some have moped plates, whereas some have MC plates. In NC my vintage Whizzers are considered Mopeds [grand fathered], however the new edition Whizzers must be titled as a MC, same size motor, just confusing laws.
I would suggest contacting Jay Cruise [PA] as he has licensed several motorbikes, and may possibly help.
Have fun,
Thanks quenton, Thats what I need to explain to the state. So lets say max power rpm is 6,800 and max torque is 4,500 and I tell them it is governed at 5,400 rpm. Do I add 2.76 plus 6 and times it by 60 teeth? I came up with 525.6 I'm not doing the math right. Could you explain the math how you come up with 25.22mph? Thanks
Hey Jim.
I'm responding to your private message.
Use these numbers from Quenton's above post:
The stock EZM kit with the HS 142 motor is shipped with a primary ratio of 2.76 X 1, and a secondary drive ratio of 6 X 1. With the 60-tooth rear sprocket it is 16.56 X 1.
2.76 X 6 = 16.56:1...
I will indicate RPM at 25 MPH on a 26" bike..........
16.56: 1 = 25.22 MPH @ 5400 RPMs.
Then use this calculator:
Speed Calculator For Go Karts and Mini Bikes
25mph is right on the money at 5400rpm.
I live in Lancaster county, PA. I have been into motorized bikes for almost 2 years, and most of that is steady time on the road. When I finished my first build, I lived in Pottstown, PA. I have only been pulled over once, midway through a 50 mile trek from Lancaster to Pottstown. I pass cops all the time. I used to be nervous, but not anymore. After this much time on the road and so little trouble with the law, I have decided not to spend the ridiculous amount of money to register. If you dont get pulled over, and dont travel all over the state on your mb, why worry about registration? if enough people register, it will attract the states attention and the cops will start harassing those of us who cant afford to go through this ridiculously expensive process. I dont have $500 to spend on registration, and certainly cant afford to go 6 months without riding while waiting for the process to complete. my bike is my main source of transportation, my only way to travel without relying on others, and its also my freedom and my biggest enjoyment. im a rebel and i like it that way.
l've seen a simular scenero where dirt motorcycle riders were for a time exploiting a legal loophole. Flordia owners of dirt racing motorcycles were getting street legal titles and regristrations through the mail from New Hampshire. Sooner or later the frustrated local "gummermint officials" put and end to that.
Someone with a lot of will and inginueity might be able to find a state that will simply register as moped and be done with it all.
I bought a yamaha zuma 125. It was not cost or the time that was a factor, It was the charging system that I couldn't wait for. I will build a bike some day when the charging system is developed. Big butterbean, After the inspection, I read that we can get instant tag and title from brimmer's auto tags.
here are a few differences between mb's and mopeds. one is cost. if you get a pretty basic bike and stick to a stock setup, mb's are probably the cheapest vehicle you can get your hands on. another difference is that some mopeds can have slightly larger engines, up to 90cc's. another is a lighting system. mopeds have a battery and generator for lights and turn signals. other than that, they are pretty much the same. people who buy mopeds are not ingenious enough to make a mb work for them. thats good that you heard that about tags. good for you. im still not paying 500 dollars for a tag i dont need.
If you read through this thread up to this point then its about time
for a recap...
Option 1 (for the Brave and the Free):
Install your gas motor - ride and hope you never get pulled
over. This is the least expensive option (assuming you never get caught)
If you do get caught then it could could cost you up to a $160 fine.
The citation undoubtedly varies by locality. You might only
get a warning - or they might take your bike away.
In any case, ride sensibly, if you see a cop start peddling.
Don't do something stupid that begs them to pull you over.
This is probably the best option if you live in a rural area of Pennsylvania
and Barney the cop is your best friend's sister's husband.
If you get caught, don't argue with the cop (unless it's Barney).
Protest the fine at the local Magistrate.
Some potential strategies with the Judge (these are untested recommendations):
1) Plead ignorance. Or tell them your buddy rides an electric
bike to work (and he said it was legal) and you thought it was OK
to put a gas motor on your bike.
2) "The Green Argument" - Heck, your just trying to do "the right thing"
by using less gas. Doesn't the Judge know that gas is going to hit $5 a
gallon this year? Something has to change! (might work with a liberal judge)
3) HT 727 (federal mandate) allows electric motors under 1hp without registration -
Why should your little 48cc gas motor be treated differently? (See Option 5)
4) Tell the Judge you would actually prefer to register and pay insurance -
IF the Judge would be so kind as to issue a court appointed moped title
on your behalf, right then and there on the spot!
Option 2 (for the persistent, with time to kill):
Try to get your bike titled using the Enhanced Vehicle Inspection method.
This takes much effort. money, & time - with the possibility of not
happening at all.
The inspection stations don't like doing this for several reasons:
1) Because of the perceived liability on their part. Why should they risk
declaring your contraption road worthy when it could potentially come back to
bite them in the ass when you have some kind of weird accident and the
insurance company starts investigating? Same goes for the bureaucrat in
Harrisburg processing your paperwork.
2) If the inspection station is a motorcycle shop, then why would they do this?
They would rather sell you a new moped! They have no vested interest in
helping get your project off the ground. In fact your vain attempt to get
a title is now a new kind "entertainment" for them.
For this reason, and if you go this route, don't take it to a station that
is a motor cycle shop. Take it to am Enhanced Inspection station that does
motorcycles - but where motorcycles are not their primary business.
Side Rant...
IMHO - This is the how the law is "corrupt". More than likely, (and a long time ago) someone influential in the motorcycle biz probably lobbied all they could to
"make sure" the laws we arranged as they are so that they could sell
more mopeds & motorcycles.
Don't believe it?
Then tell me why every mechanic shop in PA has to have their own emission
equipment and rolling dyno? - whereas other states have centralized inspection
stations run by the state? BECAUSE THE SHOPS & DYNO MANUFACTURERS LOBBIED FOR IT.
And PA car owners pay dearly for this...it all comes out of our pockets.
I also believe the law is made intentionally circular and confusing so as
to allow individual municipalities to enforce it at their whim.
Don't even get me started on the Liquor Control Board...
End Side Rant...
Option 3 (for the sly and sneaky):
Buy a junked moped with a valid title. Make sure you you have the seller come
with you to the title shop to sign the title over to you. Get a bill of sale.
Get your insurance, and a tag.
Cut the VIN plate off and DESTROY THE OLD MOPED. Put the VIN plate & tag
on your motor converted bike.
Optionally outfit your bike with the proper lighting the state requires.
But remember, mopeds are exempt from state inspection
(unless your trying to get a title! - as in Option 2) so it is unlikely
that a cop will pull you over in the day if you are missing a light.
Believe it or not, this is what the Kit car folks do.
There is a brisk market for old Ford roadster & coupe titles in the back of
Hemmings Motor News for for guys putting together Ford cobra kits.
I spoke to a guy at the Carilse Auto show who explained this to me.
Those old titles are like gold. They sell for something like $600.
In the end, all the cop cares about is that you are registered and insured
and he has no idea what a 1978 Puch moped is anyway.
The only problem with this is that it is extremely difficult to find
a junk moped with a title. People either loose the title or
just keep fixing them up, especially now when the price of gas is so high.
Which begs the question,
"Maybe I should just get the moped running and ride that instead."
Option 4 (for those who "Go green" and have lots of green to burn):
Go to hub motor, brushless motor, BLDC motor, bike conversion kit, brushless controller,electric bike,wheelchair controller,electric wheelchair,dual drive ebike, electric motorcycle,EV battery,electric boat ,brushless joystick controller, regenerative brak and order the 750w electric motor kit with the
36V16AH battery and you're good for a 30 mile range at 25 mph.
The only problem here is that it will cost you about $700 + $250 shipping.
But now your not really saving much gas money compared to putting that $130
2 cycle motor on now are you?
Lets do the rough math...shall we? Right now it costs me $75 to fill the tank
on my Explorer and that can last me about 15 days of commuting. If I could
just throw the 2 cycle on my spare bike for $130, it would pay for itself in
about 35 commutes. That's not too bad. Pays for itself by the end of summer.
If I go the electric route it will take about 215 days of commuting.
Pays off sometime in the next two years.
It all depends what you think the price of gas will do in the future.
If gas continues to go up (or stays where it is) then the electric bike
"wins" in the long run. Mainly because you don't have to buy insurance/registration
every year.
If you get pulled over on an ebike by an unknowledgable cop just show him a printed
copy of HT 727. If he doesn't buy it, then take it to the Magistrate.
You at least have a foot to stand on.
Option 5 (For all of us in the long term):
We all recognize the PA laws regarding pedaled assisted bikes are incorrect.
Especially when compared to many other states and with the advent of HT 727
for electric bikes.
Can we all collaborate here (or someplace on the web) and start a petition
to see what we can do to get the law changed? If the gov't of Egypt can be
overthrown by Facebook then I am sure we can get something done...Right?
Hi guys.. I am new.. I just got pulled over last night on the bike.. I have a suspended license due to a DUI.. I live in pa.. They stated I needed a drivers license.. And charged me with 1543B-- driving on a suspended license.. I spoke with one lawyer today and be was totally baffled....! The officer pulled me over saying I did not have enough light on the bike was his probale cause.. My lawyer is going to look into it.. I'll keep you updated... Pendot here in pa would not answer my question and said I would need to
Get the bike registered but I advised him their no vin! He stated he did not know and to seek a lawyer... On the ticket it stated I drove a motorized pedalcycle.. A motor driven cycle
Is a scooter not a bicycle. Pa refers to
Bicycles as pedalcycles so it's vet in clear but we will
Soon find out with my case..
To Scribbles: let me clarify: you need a drivers license to drive a moped and motorized bicycle in Pa? And u cannot drive on the streets? Thanks
Hmm interesting. I lost my DL due to health issues. here in TN. a motorized bicycle IS allowed but need a helmet. ( and lights. both of which HIGHLY advised to have) I ride a goped trail ripper40 aka a gtr40 a stand up scooter capable as it sits of 52mph via gps. cop gave me **** cause I didn't have my lid on. yes I was a fool lol. ill admit that. I wear my lid now no matter what. id advise this. make sure your bicycle is NOT able to be ridden off road. if its a MTB put road tires on it. cop said my goped was a scooter. ( I said per TCA code it is not sir. you are incorrect. I said. check it on your computer there. he said " its broken" I replied. well then you need to have that fixed.......sir. I said per TCA definition, a scooter has both a seat AND pedals and needs either one, or the other to function. a moped has same but it isn't in same class. neither one need a DL to be used. a motorized bicycle is classified as an engine assisted bicycle. needing ONLY a helmet by law. the BGF engine kits advertised as 80cc are truthfully 66. which in most locations exceed legal limits w/o a DL. tell them its 49cc. which in most locations is within limits. my gtr is 42cc. which if I try on slight hills will get me almost 55mph. Im wanting to get another motorized bicycle in trade for the goped my health wont allow much pedaling anymore. so idk. ANYHOO, sorry about the long winded reply. make sure your cycle is within limits. if not make it appear to be so.
Aaron
You need a driver's license, tags, titles and insurance to drive a moped in pennsylvania. The average motorized bicycle would be classified as a moped here. The requirements for a moped in PA are as follows: Engine displacement 50cc or under, bhp 1.5 or less, top speed 25mph or less, DOT approved headlight, taillight and brake light (turn signals not required, hand signals are acceptable), DOT approved tires, automatic transmission (no clutching to shift. Shift kits do not require clutching, so may be able to get away with it, but not sure). The process for registering is as follows. You must take the bike to a garage that does enhanced vehicle inspections (cost about $160). IF/when you pass the inspection (mopeds do not require yearly inspection here, only the initial inspection to prove it is roadworthy and meets all requirements), you take the inspection form to be notarized.You send the notarized form in with a request for a title. You will also need a VIN, and you can and should use the bike's serial number for that. Once the title is granted, you must then register the vehicle and obtain insurance. The yearly registration fee which includes the plate (new one every year) is $17, and moped insurance is about $90/yr. Drawbacks are the expensive cost of the inspection and how long the whole process takes. Advantages are that once you get a plate, you can do whatever you want to the bike. Fwiw, I am a PA resident and I absolutely refuse to register my bike. For one, I have never had a driver's license. For two, I don't have the cash to throw down. Three, my bike is outside the requirements with a 98cc engine. I live in Lebanon, a small city and the cops don't bother me at all.
Here' my take...
...I'm no lawyer, just an average guy, and I'm not addressing this to anyone in particular, you all have your right to your choices.
Better safe than really sorry, in Pa driving is not a right it's a privilege, the state owns the roads. So your paying to use their system. We all like to get somewhere, roads allow us to travel freely within limits, the limits are, following their rules. Roads can take us everywhere, and are really great if ya just wanna go for a spin also!
I know it is a huge task to jump through all the hoops. But let's just say you have an accident and your not legal, the 6 months you would have waited for all your paperwork will seem small compared to years of legal battles. You will prolly almost likely loose your motorized bicycle. Now if you did damage to another person's vehicle property, or worse yet body your in for a really rough ride. What it is going to cost you as far as you being liable. All the excuses won't fly in court, the entire system is stacked against you. What would be your excuse for not being legal, I didn't know? Ignorance of the laws isn't acceptable, damage was done by you. You drove on the roads with no concern for laws or other persons safety or even your own safety. You will have to pay out of your pocket, if you can't pay, a lien might be applied to your wages or your home.
I went through **** getting a dirt bike legal, but it was worth it. I ride and enjoy the rides, yes I still worry about crashing, but at least I have insurance, title, tag, and inspection. So if I have trouble I have support in place to fall back on.
I was once pulled over by a cop who though I was on a non legal dirt bike, it does look like it. I spoke with him showed him all my papers, and he was amazed that I actually had everything in order, and apologized to me for stopping me.
Believe me I hate some things in life just like the next guy or gal, doesn't seem fair some of this stuff, but if given the opportunity to feel at ease, and protect myself as well as others...
...well... just my take, now back to your favorite motorized bicycle thread
Kakashi_12, if you're asking who I got insurance through, re-read the end of my previous post and you'll see that my bike is not registered. I do not even have a license. MTB Moto, I understand where you are coming from to a point, but.....The state only owns state roads, not all of them. Other roads are owned by the county, city, borough, township or municipality in which they are located. Some roads are also privately owned. In Pennsylvania, whoever pays to have the road maintained is who owns it. Secondly I do understand that driving is a privilege, but I feel that the government abuses its power to exercise its authority over what we can and cant do as American citizens sometimes. The law in PA used to be that if it was under 50cc, the cops could not touch you. You did not have to register it, and you did not have to have tags, title insurance or even a license. Yes its true that if you are in an accident, you may be liable. But if you drive out on the road illegally, you accept that consequence the moment you take off from a stop under engine power. As it happens, I was in an accident in 2009 in Pottstown PA. I was driving a 49cc 2 stroke kit bike. The cops did not ask what size engine it was or give me any sort of hassle about it whatsoever. The lady who caused the accident's insurance company paid for my hospital visit and sent me a check for $100 for repairs to the bike. I was never given a ticket or denied the insurance coverage. The accident was not my fault, so perhaps that played a part. My experiences driving around various parts of PA have led me to believe that most cops here do not know the law. I obey traffic laws and I am very careful on my bike, always paying attention to everything around me, especially because I know that the cagers are not paying enough attention. But I still take the risk in my hands every time I set out on the road, and thats my choice same as it is everyone else's. Just saying.
