hey biknut, is that red head on there spaypainted or what? I'm looking to do a color-scheme to one of my engines, all blue with all the edges black and faded into the blue center. I don't remember if oriely had 1200 degree paint that was any other color. I'm sure they had the 500 degree paint in other colors, just not too sure on 1200. also, did you have to prime the engine? Or should i just douse it in rubbing alcohol?
I've used plain old spray paint on engines, both 2 and 4 stroke and never had any heat issues. I like to match the engine to the bike color and I've used DupliColor, Krylon, Rustoleum and model airplane paint and none of them have been affected by engine heat. That includes the area near the exhaust port/ pipe flange.
I think engine temperature is overrated. They just don't get that hot to need special high-temp paint.
I don't paint my pipes, I polish them and pipes aren't the engine.And how about on the header pipe? A little different story there.......![]()
As far cleaning the engines, use quality gasket materials, check the torque on your fasteners and the engine will stay clean with no need for aggresive cleaning materials.
Any excess chain lube or intake blow back will wipe off easily with an absorbent cloth.
A good thing about Dupli-Color Engine Enamel is, it's mostly unaffected by fuel spills. Some of the other heat paints I've tried, the finish was ruined if I spilled any fuel on it.
I live down 3.5 miles of very dusty caleche dirt road, my chain and engine, actually most of bike stay quite dirty all the time, I use brake cleaner for cleaning chain and around the carb where the blow back oily residue forms and mixes with caleche dust that almost sits up like concrete, very hard to get the stuff off, high pressure water wont hardly touch it, thats why I use the carb cleaner and the brake cleaner to clean on mine.
If all I ever rode was pavement, that would be a different story but make two trips down my roads out here and you'll be getting out some chemicals to clean things up...LOL!
Map
I like to use electrical contact cleaner to quickly, and effortlessly remove grease and grime from my bike. It doesn't harm the paint, but the downside is, it's a little expensive. The cheapest I've found it is at walmart.
