TheNecromancer13
So I'm installing a motor on my bike this weekend, and I've been reading up on all the problems I might run into. I noticed that the chain tensioner seems to be almost universally hated because it comes loose and falls into the spokes and makes you crash. So I've been trying to think of ways to fix it, and I thought of a few ideas and was wondering if anyone else has done this...
Once I try one, I'll post how it worked.
#1) Take a strip of metal, drill a hole through one end, and install the tensioner like the instructions say, except where the little pulley attaches to the metal arm, take that screw off, and put the metal strip on first, then put the other stuff back on (so that when I install it, the metal strip is on the outside and the pulley is on the inside). Then, when I install the tensioner, I put the metal arm on the horizontal bottom bracket, and then, once I've got the tension right, I attach the metal strip to the diagonal upper bracket, maybe with one of those clamps you use to fix a garden hose and some old inner tube or something (I'll have to see what works when I get the kit). That way, the pressure of the chain can't force the tensioner sideways into your spokes, and it will have to get a lot looser before it fails, and even if it does, the failure won't involve screwing up my spokes.
#2) Extend the metal arm on the stock chain tensioner, and mount it from the diagonal top bracket, so that it goes down past the top chain, and pulls (instead of pushes) the bottom chain up toward the diagonal top bracket. This would make it so that the pulling force of the chain does not exert leverage in a direction that would force the tensioner into the spokes, instead it just pulls it straight out, so again, even if it became loose, it would still function and I would notice it loosening before it got to the point where I crashed. Might have to bend the arm to move the metal out a bit so the top chain doesn't snag on it.
#3) Share your own ideas, if they're better than mine I'll use them.
