It is common for the scraping with the bell rotor and the 100t pulley on this kit. I have found you have to use the cam tool to tighten the belt just right to get the scraping to a minimum. Then after some miles it will get quieter as the metal on metal contact wears a little bit. Also change the half key for the clutch immediately. It helps with the chatter when clutch engages on take off. The key shipped with this kit is weak and wears quick. allowing the clutch to have movement on the shaft. It will still chatter with the new key, but not as bad. I did not change the key and within 100 miles it was unbearable. I also found adjusting the valves to .006/.008 from .004/.006 smoothes out the chatter from take off as well. Must be something with the torque curve, I am guessing less power at 2100 rpm where this clutch engages, allowing for smoother engagement. Good luck, you have a good kit, just have to tinker a little.
