Egor
I love this. Answer, a rough intake and a short fat one. I like long stroke engines, I like to stroke all my Honda's. With a larger bore it will keep the revs high but when you stroke that same engine it then will pull and where you knew the other engine would give out the stroker would make power you just need to use it differently. I never got to actually get out on the track, except to try the engine. I built a lot of racing engines for the locals. One engine I had fun with was the old CB72 Honda for a 1/2 mile rider. I got most of the power out of the cams porting and the most important mod was the exhaust, I left all the standard ideas behind. I used the header size off of a 125, it had a 1" inside diameter it looked kooky but the thing would power like you never would believe. No one ever copied the idea cause it was just to out there. But it was just two 125cc engines running together. I like the way you think, I believe you about the temp reduction from the paint because of the extensive testing you have done, so I will add that to my reputuar, Thanks. Have you ever used the Prolong engine oil? I would never think anything would add to a good oil, but one of the Ford engineers had the data to support the stuff. I later had the opportunity to try for myself. We had a Dredge I was operating for the city, it had a bad alignment of one of the bearings that drove the pump, any way the thing would boil 120WT gear oil in 3hr. I added the Prolong and we never had to worry about the bearing again and you could now place your hand on it! Part of the learning curve for me. The engine was a 1200ci OHC Cat. Have fun, Dave
PS: I loved the Ducati, I had a 250, though I never got to enjoy it. As I got it built I got a good offer for the thing, I was building a Royal Enfield / Indian 750 twin that was my main focus. My ideal dream motorcycle its the Velocette Venom, I used to build them and vouched to own one some day, maybe in the next life. LOL
CLEANED UP THE TUBE HEADERS AND REINSTALLED THE NEXT DAY = BACK UP FRONT!! THAT WAS A 4 STROKE ENGINE , OF COURSE. THAT ENGINE HAD THE TUNNEL PORT HEADS, THE FACTORY ENGINE W/DUAL 4V HAD MEDIUM RISER HEADS. DO THE 2 CYCLES RESPOND DIFFERENTLY = NEED MORE BACK PRESSURE ?? WHERE CAN I GET SOME TURD POLISH FOR MY FRICTION DR MB ??
THANKS, RON
I HOPE HIKER ISN`T CHARGING FOR USING HIS EMOCONS!!
