silverbear
The Boy Who Never Grew Up
Even though I'm in the middle of setting up SBP shift parts on my build (3 speed Elgin Velocipede 1934) I still don't understand how you start your engine. I'm using a PK-80 China Girl with manual clutch and a Sturmey Archer 3 speed internally geared rear hub.
Correct me if I'm wrong, but you are no longer able to bump start it, is that right? If that's the case, how do you start the engine?
Second question... you are riding along and it is time to shift gears. Do you need to release the clutch when shifting or is it enough to just let off the gas a little, shift and then give it gas?
I'm trying to figure out my handlebar controls. I have an old three speed twist shifter I'd like to use rather than a thumb lever type. That would be on the left, throttle on the right. Drum brakes front and back, but I'd rather use separate levers in case something happens to the cable, lever or one brake. So one brake lever on the right and one on the left. I also have to have the clutch lever on the left. So that's two levers plus the twist shift to co-ordinate with the left hand. Right hand is busy with the throttle and right brake lever. So, it makes a difference if the clutch has to be disengaged in order to shift.
Thanks for taking the time to read this and offer some advice to a shift kit newbie. Maybe your answers will help someone else, too.
SB
SB
