Bikeguy Joe
I couldn't have said it better Clotho.
Thank you.
Thank you.
I'm surprised no one here has mentioned reed valves. I think they would help overall performance. The last post I saw with reed valves said that top end didn't change that much but every where else was better. I'm starting to work on my own design reed valve system. I hopefully will find one that already exists and only needs little modding for our application.
If anyone else has any input let me know.
Tap. Tap. Tap. Is this thing on?
I will try to paint an analogy to make this concept easier to grasp:
The balloon has a hole in it. It doesn't matter how good you are at blowing air, the balloon will never inflate. (you will not achieve a boost condition with a piston ported 2 stroke.)
The hole in question isn't exactly a pin prick. It even has a name. It is called "Exhaust Port"
You must solve this problem first. You must plug the hole. Until you plug it with something you can blow all day long and you will accomplish diddly.
Calling it a supercharger was a good start however. At least a supercharger is some form of compressor and not just a fan. Fan's move air very well but they don't compress air very well. Fan's don't blow balloons up very well.
