HELP NEEDED - Install on a 3 speed coaster hub
Discussion in 'Motorized Cruiser Bicycles' started by imlivingproof, Mar 23, 2011.
  1. imlivingproof
    imlivingproof New Member
    Mar 23, 2011
    Is it possible to mount a Zoombike 80cc Kit on a Schwinn 3 speed cruiser?
    I am having trouble installing the sprocket on the 3 speed coaster hub.
    Can I go to a one speed?
    Any help would be great
  2. Ursus
    Ursus New Member
    Aug 12, 2010
    45
    What problem are you having exactly?
  3. imlivingproof
    Mar 23, 2011
    I need to mount the sproket, and it asks me to remove the brake arm. But when doing so the hub opens and starts to...
    Also I just installed the motor but cant get the sproket inside the motor to spin, any advice on that would help
  4. Smoothe
    Smoothe New Member
    Sep 12, 2008
    201
    Maybe I can help you a little bit I.L.P:
    Pull the clutch lever and your engine sprocket should spin.
    Take your wheel off your bike, lay it on its side, carefully remove the coaster brake arm, don't lose any parts, attach sprocket, replace brake arm and anything else that may have come undone. Add chain, replace wheel, ride like HECK!
    That 3 speed hub sure would be sweet with a shift kit, and no need to remove the brake arm!
    #4 Smoothe, Mar 23, 2011
  5. driftology
    driftology New Member
    Jun 22, 2010
    125
    i would go with the shifter kit too!
  6. imlivingproof
    Mar 23, 2011
    I will try it out when I get home.
    Does anyone have a 3speed coaster hub with a sprocket added? If so I would love to see pics.
    If I can't figure it out today I think I might just convert it to a regular hub and add brakes to the bike...
  7. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    if you could make a video showing the issue you're having i mite be able to help, i had no major issues putting a sprocket on my coaster hub, although mine was a single speed.
  8. imlivingproof
    Mar 23, 2011
    Update:
    I'm buying a single speed coaster hub on rim. It will be installed tomorrow afternoon.
    Also I got the sprocket in the engine to spin, it turn out I didn't pull the clutch far enough back.
    Thanks for all the help
  9. Smoothe
    Smoothe New Member
    Sep 12, 2008
    201
    And what are your plans for the 3 speed hub?
    Are you going to use the rag joint sprocket? I would check out the Manic Mechanic hub adapter & sprocket at Pirate cycles. 40T sprockets are sposed to be optimum for 2 strokes.
  10. Bikeguy Joe
    Jan 8, 2008
    11,529
    Most (if not all) 3 speed hubs are too large to fit the sprocket over, unless MM makes a sprocket adapter with a GIANT hole in the center...
