Don't fall into the false claims of many people on here with bone-stock china motors hitting 35+ with a 44t sprocket. Their speedometers are wrong. It just doesn't happen. The gear ratio with a 44t sprocket and 26" wheel simply don't allow it. Often, the 26" preset is not correct on digital speedometers, and mechanical bicycle speedometers are often not intended for such high speeds and don't have a linear curve, so as you get faster, the speedometer keeps getting less accurate. Also, don't fall into any rumors about "drilling your muffler", just tune your jet to the pipe and you'll have the same effect but much quieter and with a better torque curve and higher efficiency. If you want a tuned pipe, get a tuned pipe instead of a drill.
As far as hitting 30mph, I cruise at about 25-26 and top out at 30 with a stock non-cat exhaust, NT carb, 40t sprocket, and matched ports. Verified with a GPS, accurate speedo, and car.
I thought your statement about "false claims" was a bit harsh but the weather has been to crappy to ride, so... It hit a whopping 60 degrees today so I strapped my GPS on my bike and took it for a (very chilling) ride. I am glad to report the spedo on my bike was 100% accurate when compared to the GPS all the way up and down the speed range, actually, the few seconds it was off I found it lagged the gps by 1MPH.
Today my top speed was 33.3MPH as you can see from the picture of my GPS... I purposefully took any terrain with even a slight decline at less than 20MPH so I wouldn't screw up the statistics. The speed was attained on a smooth flat asphalt road, the bike is NOT running anywhere near it's peak performance of earlier this summer. The rear tire has a bad wobble now and I had been doing some fiddling with the carb and it is not tuned for well for top end right now.
Recently (on a warmer day and longer ride) my bike spedo recorded 34.6MPH (with the same setup I am riding right now), my previous top speed recorded was 36.8MPH, all done on the same stretch of road as above. The 36.8 was attained before the rear wheel wobble became an issue and the carb was tuned a bit better for top speed then.
I have a STOCK Grubee 2010 SkyHawk 66cc kit (from GasBike.net), running the sprocket that came with the kit and the motor has all stock parts, but I will list the things I have done that differ at all from the kit:
NGK plug
Quality automotive wire and boot
Cleaned out extra material from inside intake at elbow
#41 Chain
Metal Throttle grip
Eliminated chain tensioner by adjusting motor position
TUNED CNS CARB
Thats about it, pretty much stock other than some durability upgrades, certainly no "performance upgrades" on my engine (maybe next season!). Did I mention that I TUNED THE CARB? LOL I have done a LOT of fiddling with the carb, really happy with how she runs after I got the carb in the right ballpark. I am still fine tuning it, right now my low end ride is super smooth but top end is a little limited. I KNOW I had been going a LOT faster than I went today in the past because of the sound and feel of the ride, I had the carb tuned up for top speed earlier in the summer. Over the winter I am gonna source an aftermarket air filter and will tune the carb again in the spring, hope to get her back to hitting the upper 30's again next season...
