Hello, I have an 80cc 2 stroke engine with a 36 sprocket adapter kit which I put on a beach cruiser and the other day when I was going home from work, all of a sudden a bunch of gas started to leak all over the engine. The bike was used so I decided to replace essentially everything new (I had another kit laying around). I didn't want to install the new engine if I can help it, since I don't believe this one is dead dead but ever since I put it together I've been having issues.
When I pedal and release clutch, it will start up but my throttle doesn't rev at all, and when I disengage the clutch (pull in the clutch lever) it just dies automatically.
I've done the following so far:
I've replaced the carb with a new one to fix the flooding issue
Switched out the clutch cable with a new one, it engages properly
The Throttle cable appears to be installed correctly, when I turn and let go it goes back into original position, but no rev. I've checked inside (removing the air filter) and saw that the pin does go up and down.
I replaced the CDI/spark plug with new ones, I wired it per the diagram the kit provided.
I'm stumped.
If I pedal it will remain on but no throttle response and if I pull clutch lever it will die
I'm stumped.
