KilroyCD
KilRoy, Are you running the engine/oil switch or did you bypass it? Stock carb? Also were you guessing on the 4500 rpm or did ya check? Thanks, Evan
Evan, the 4500rpm is an estimate arrived by us through crunching numbers. We are running the engine/oil switch and using the stock carb but disconnected the governor. The Whizzer WC-1 air cleaner was modified to fit the stock carb.
