Train_Wreck
Hey everyone. I know this question has probably been answered a bunch of times, but I keep seeing differences of opinion on what ratio to use for the break-in and after the break in. So far I have broken in my engine with 16:1 using Lucas Semi-synthethic High performance oil, now I am done with the break-in and I need to know the oil ratio for normal riding. The vendor that sold me the engine says the ratio should be 20:1 or 25:1 after the break in, which seems right but I have seen a few crazy numbers thrown out there from other people saying 50:1 or even higher. I'm assuming that's ok if you have a really good oil, but I'm not sure if mine is that good. If anyone can give me some suggestions on what I should mix, I do not want to run anything too lean. Keep in mind I am NOT changing the oil I use, It has been working fine for me for my Go-Ped for years.
Thanks,
Igor, a.k.a. Brian
Thanks,
Igor, a.k.a. Brian
