this seems to be a problem some people have with the carbs that come with the 2 stroke kits. if this happens take the float bowl off and check that the fork that lays on the float inside the bowl, is sitting up far enough. just bend the fork up a little and now it should stop the leak. the fork when pushed up, also push in a little pin into the bottom of the fuel inlet and stops it from over flowing. when it over flows it finds a place to come out and that usually is the primer button area
