snobord28 New Member Jun 9, 2010 #1 hey Im mounting a custom tank and wanted to know if the fuel line can run slightly upward along with the frame. Im mounting the shutoff where my thumb is as you can see in the pic it needs to go upwards to look right. thanks all Attachments fuelline.jpg 14.7 KB · Views: 230
Dave31 Active Member Jun 9, 2010 #2 As long as the tank is higher then the carb it should work....I think.
Cabinfever1977 New Member Jun 9, 2010 #4 When you turn the petcock on the fuel will act like a rollercoaster, it can go down then up then down. It should work fine.
