Front engine mount/ 2 stroke/ DAMAGE?
Discussion in 'Motorized Bicycle General Discussion' started by T Rock, May 12, 2010.
  1. T Rock
    T Rock New Member
    May 5, 2010
    Is it bad to drill a hole threw your frame to mount your front engine mount with a big tube frame ? I heard stories about how it could damage your frame. Is true or is this a myth ?
  2. dvddtz
    dvddtz New Member
    Feb 15, 2009
    162
    I have only drilled one frame out of 14 builds,and I rode that bike for around 2500 miles and then sold it.But I would suggest not drilling if at all possible,as it will weaken the frame in that area.And it was a steel frame,Huffy Cranbrook.
  3. Bikeguy Joe
    Jan 8, 2008
    11,529
    I would avoid it at all cost, since there are a hundred other ways to do it without drilling.
  4. T Rock
    T Rock New Member
    May 5, 2010
    thanks for the info guys, saw a lot of pictures where people have drilled a hole threw the front tube, it kinda made me cringe. I think the muffler clamp looking mount might be a better set-up. The reason why I ask is that im building another bike this weekend and it has a big front tube and wanted to do it the best possible way.
  5. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Muffler clamp to a bracket. No reason to do anything else unless you're a welder.
  6. metalliatic
    metalliatic New Member
    Mar 14, 2010
    96
    it wont hurt anything. i did mine that way and its a good way to mount it solid with out the motor moving. there probably is a better way to do it but this is cheap and easy way. my frame was curved and had a big bottom tube so that was the easy way for me.
  7. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    No need to drill , theres always clamps and brackets you can get or make.
