Front brake kits
Discussion in 'Motorized Bicycle General Discussion' started by muldrick, Jul 15, 2010.
  1. muldrick
    muldrick New Member
    Apr 14, 2010
    10
    I want to order one for my Cranbrook. (hope it'll work with the wheel).
    Who's got the kits?
    I saw one at Piston Bikes but I don't care to pay $18.00 shipping.
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    You can buy a vbrake bracket, and a set of vbrakes, and a cable, and have vbrakes, or you can spend just a little more and get a heavy duty wheel with a drum brake:
    26" FRONT WHEEL WITH DRUM BRAKE HUB: Husky Bicycles
    I got one, it's about $95 shipped, and well worth it. Super easy to deal with, and better than vbrakes. You just have the bend the long brake arm so that it rests up against your fork so you can clamp it properly. Couple more bucks for a hose clamp, and tighten it up good.
    Edit: Oh, I'm in the US, for the record. I just noticed you might well be in AUS.
  3. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    What does the v-brake clamp look like and where can you get one?
    I am picturing it being something that goes in the little hole in the top of the fork that allow the use of v-brakes?
  4. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    This is what i put on the front of my huffy, it is a U Brake caliper, not quite as good of a brake as a V Brake set up but much easier to put on your Huffy and cheaper as well, it also has the brake shoes that are made for a steel wheel, and most V brake set ups are designed for bikes with Alum. Wheels and the pads on them dont work as good on a steel wheel.
    Check out this guys store and you will find loads of brake stuff, I have ordered from this guy and he shipped quick and has some good prices.
    NEW BLACK BICYCLE CALIPER BRAKES BIKE PARTS 301 - eBay (item 230378795901 end time Aug-13-10 08:29:50 PDT)
    PAIR OF BLUE ANODIZED LOWRIDER CALIPER BRAKES PART 456 - eBay (item 290429694122 end time Jul-26-10 15:00:49 PDT)
    PAIR OF RED ANODIZED LOWRIDER CALIPER BRAKES PART 455 - eBay (item 290429694582 end time Jul-26-10 15:02:52 PDT)
    PAIR OF LIME GREEN ANODIZED LOWRIDER CALIPER BRAKES 539 - eBay (item 230476698021 end time Jul-17-10 15:02:17 PDT)
    NEW CHROME BIKE CALIPER U BRAKE BICYCLE PARTS 362 - eBay (item 230370748661 end time Jul-20-10 11:45:36 PDT)
  5. Venice Motor Bikes
    Mar 20, 2008
    6,175
    I sell front disc brake kits for all bikes.
    Disc brakes work the best... & because they're the best, they're also the most expensive! :(
  6. taddthewadd
    Mar 1, 2009
    339
    How much Venice, and how do you mount a rotor to the front hub? Don't tell me with a mini rag joint Lol!
  7. Venice Motor Bikes
    Mar 20, 2008
    6,175
    I use a Shimano front disc hub, 160 rotor & my custom caliper brackets.
    I have the whole kit for $120.
    PM me.
  8. muldrick
    muldrick New Member
    Apr 14, 2010
    10
    Mapbike,
    Exactly which kit did you get?
    My Huffy Cranbrook (from WallyWorld) has the (what looks like) aluminum wheel.
  9. mapbike
    Mar 14, 2010
    5,380
    The one I have on mine is the first link I listed, it should work fine on your bike, I listed the additional links just so you could see that the guy has a good amount of options, just ,make sure that if you order from him or anyone else that they list the length of the caliper arms because anything shorter than 4" inches will not work on the 26" Huffy Cranbrook, the ones I listed in the post above are all long enough, and should work fine on your bike.
    Here is another guy that has an entire KIT which includes everything you need, he claims the measurement is 70-90mm from center of stud to brake shoes that would be 2.75 - 3.54 inches, i'm not sure how they are measuring it so I would contact and ask them to measure from stud to end of caliper and see if it is 4" long in that area. this is a real good price $14.50 on the whole set up and he is offering free shipping to boot.
    Here's the link: BICYCLE (F) SIDE PULL BRAKE SET+LEVER(R)+WIRE TIP NEW - eBay (item 230412496848 end time Aug-11-10 14:57:24 PDT)
    #9 mapbike, Jul 15, 2010
  10. taddthewadd
    Mar 1, 2009
    339
    I am thinking about motorizing a one of the new huffy cranebrook's that has the blue painted rims. Do you think the rim brakes would work?
  11. mapbike
    Mar 14, 2010
    5,380
    YES.....................
  12. taddthewadd
    Mar 1, 2009
    339
    I guess I should clarify that. Will the rim brakes chip off the paint and make it look terrible or is the painted surface going to be more slippier and not stop very well
  13. pdubs
    pdubs New Member
    Jan 16, 2010
    74
    yes and yes.
    it will rub the paint off, and it wont be the best stopping power..
    im using this hub laced up by a local bike shop
    Front Hub - Single Disc Black - Cycles U.S. LLC/Choppers U.S.
    would be nice to keep that blue rim from the cranook and disc/drum hub.
    it gets pricey stopping without pads on the rim and custom looks.. but worth it!
    just FYI front disc brake without rear brakes can be tricky especially on hard fast stops.
    my next bike will have full disc and front suspension, couldnt ask for more :D
  14. mapbike
    Mar 14, 2010
    5,380
    Agreed......good advice! Would like to go this route myself.
