first breakdown
Discussion in 'Motorized Bicycle General Discussion' started by avery08, May 21, 2014.
  1. avery08
    avery08 New Member
    Oct 3, 2013
    19
    The chain popped off during about a 4 block ride today.I was just cruising casually.I ridden the bike 4 or 5 times,the longest trip was 10 blocks or so.Having ridden so many times with no problem it doesn't seem like a chain alignment to me,but I am new to this.The rear sprocket and the chain idler are tight and in same place I assembled them.It's a stinger sd kit in a huffy cranbrook.Any and all thoughts appreciated.
  2. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    Well get used to it. These bikes seem to think they're your girlfriend now. Lol make sure you carry tools quick links and things like that.
  3. avery08
    avery08 New Member
    Oct 3, 2013
    19
    Girlfriends always cost me a lot of money,this could be big trouble lol
  4. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,898
    23
    'nuff said.
    Hold the bike frame with one hand and pushing as hard as you can, see if the engine or back wheel moves.
    Chances are both depending on how you mounted your engine but most likely that Cranbrook coaster brake wheel is shot before the engine is even broke in.
    This is very common.
  5. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,565
    58
    new chains stretch about 1/2 inch in first 10 or 15 miles - this needs to be adjusted
    motor mount studs also stretch and need tightening often for first 50 miles or so
  6. LR Jerry
    Dec 19, 2011
    1,027
    Seems you got that part figured out. Lol
  7. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Actually only two things will cause a roller chain to derail. Sprocket alignment and/or tension.
    A foreign object getting between the chain and sprocket would be the exception.
    Many things might cause one or both to be off; engine or rear wheel moving, sprocket wobble, tensioner not set right or has moved. Etc and etc.
    You'll need to do everything you can to assure that the sprockets are aligned and that the chain tension stays between 1/2" to 3/4" of slack. Proper lubrication also plays into this.
    #7 2door, May 21, 2014
  8. avery08
    avery08 New Member
    Oct 3, 2013
    19
    I had some success today and rode it for a mile or so around town.I realigned the engine and rear wheel.Also adjusted the chain,it had stretched quite a bit.Thanks for all input from everyone,really loving this site......
