ed the the back into it after making sure every thing fitted OK...I have some 1/16" rubber to line the inside where the battery sits...this will hold it in place as well as the hold down strap which is bolted to the lower panel that drops out of the bottom...when its required to get at the electrical components...ie: CDI....Alt reguator..couple of relays....battery...ign coils....wireing....ect. The tanks have turned out pretty good and will not require any filler on the outside...probally just a little around the inside edges, as I didnt want to grind off to much and weaken the weld along the seams...this will only take a smeared to finish off.....I still have to Dremel grinder around the filler cap and mounting nuts ...thats silver solder and wont take much to dress up....DD
