cannonball2
Got my shipment of batteries today 87 in all will use 84. The cells are new Samsung 2200mah removed from surplus battery packs less than a year old if the seller is telling the truth. The pack will be 51.8v nominal with a hot of the charger voltage of 58 and 13.2ah. Built a small rack to hold the cells firmly in position for soldering in groups of six. Two groups will be joined in series for a single 7.4V 13.2ah cell. There will be 7 of these cells.
Since Im not running a BMS my thoughts are to make the cells modular with connectors. This would allow balancing of the individual cells occasionally, as well as the ability to up voltage at a later date simply by adding modules. This will likely require a special built box with a easily removable lid. I also bought 10 single cell holders that I will parallel to initially balance the cells. Waiting on some special wire to make the cell connectors from. Then the build will begin into the cell modules.
