Dyno Kustum kruizer project.
Any of you guys have experience motorizing this frame. theirs a local guy here in town i can pick the frame up for around $200.
Personally i like it its low, stretched, and has monarch forks. The only issue i can think about right off is trying to figure some way to mount the engine and have it mesh with the drive train the right way. i will probably be going spookytooth for one of their newer belt drive four stoke systems and rocking their $130 HD rear axel with band break. Hopefully down the line ill will also be able to rox front disc breaks as well. any thoughts folks?
I have enclosed a picture of the bike i will be using.
One of the only down side is the front forks are not as intense as i would like. as in chopper style, i want longer forks but am kinda concerned that without modding the front steerin cassette my rake may be screwed!
their still in operation, i also found those hd axels /band breaks sans being laced going for $30. as far as a iknow they still in business.
Hi Guys
Sucks that Spooky tooth is closed if you want the HD wheels for pull stat engines I can help you out
Cheers
Terry
Hi Guys
Cheers
Terry
Good call, Im looking for an 11 or 12 gauge rim with a coaster brake with both sprockets and sealed bearings already on the rim. Can you get something like that?
I believe the answer is/was "no" Jeremy. This is an old post but are you up for a ride? Next Sunday?
