MEASURE TWICE
I have checked with repair shop for the slight roll before grabbing to stop the vehicle on a Manual Transmission truck and they said it is normal. Drum In Hat (DIH) is the small drum brake inside the Rear Wheel Disk Brakes. This mechanic checked it and said it is different that my prior truck which did not have 4 Wheel Discs (w/DIH). The same model truck in the past had Disks in front and Drums in rear, so that is why this happens. Thinking maybe not so fast. I have found many having this same thing happening and have not had answer with specifics why it happens. I sure would like to know as I think it is @%^#$.
Depending on grade of slope when parking it can be 1 to 3 inches of roll before it grabs. Not very comforting. The amount of hold once it grabs is just great once it goes any where from 0 to 3 inch of rolling. The parking brake pedal only needs normal pressure and goes just half way the travel to the floor, so that is good. Looked at the cables and they are fine.
In neutral with the parking brake set and the engine off on level ground I am to get some chalk to mark where the wheels are when vehicle is pushed and expect to see this play. Forward to Aft roll measurement is what I want to know. Then when I know exactly the amount I can check with manufacturer rather than the place that did my brakes about a year ago and find out what is said.
Anyone come across this and have any way to fix if in fact it is not normal?
PS
I always put in reverse (lowest gear) when parking along with the manual shift DIH Parking Drum Brake Brake.
PS
