All I needed to do to get a workable clutch with my Martin and Slater clone was to put a hardened machine washer under each puck post, and I drilled oiling holes in the pucks for the beleville spring washers and stacked them all ( ) ( ) to each other, works great so far, you need the right gearing for the stock clutch to work, like duplicating the chain tension on a KTM50. If you try and lug the motor and spin the clutch away its bad, I had that problem and gearing made the stock clutch work like butter. I use Redline brand D4 ATF in my case, about 250cc.
