Thanks, Shiloh0. It is my quickest bike.
bigalan, with 25:1 oil/fuel ratio, this sucker spits out a lot of oil. I might have mispoken; ya need to wipe the oil mess after every run. Then again, my Tanaka has 50:1 f/o ratio and still spits quite a bit of oil too.
Be sure the engine is well-insulated, or your hands might get numb. I insulate my engine drive system with swatches of bicycle tire, not bicycle tube. They work well.
The clutch spring broke recently and the 5:1 tranny needed relubing. After filling the tranny with grease, the 460 was replaced with a 2.8hp Tanaka 47R engine. I mounted the Tanaka upside-down too, so that I was able to re-use the Happy Time expansion pipe and HT 4-liter fuel tank. Engine size is similar, although the 460's exhaust tube hugs the bike frame tighter.
The 460 with SBP expansion pipe is MUCH quieter than a Tanaka 47R with the same pipe. With the Tanaka being so loud and all, it's hard to wind it up to its max. It's no slouch, though.
For the price, ya just can't beat the GP460 engine. It's the most powerful engine that will bolt onto available engine drives. The shift kit and the NuVinci hub work extremely well with the 460. Single-speed systems won't work well with hills.
For the amount of power it produces, the 460 has excellent gas mileage, much better than the Tanaka.![]()
I have installed my GP460 engine with friction drive onto two bicycles. This engine eats rear tires quickly. One tire lasted less than two weeks. Every time the engine roars to life, it will literally take a chunk of rubber outa the tire. One of my tires had divots 1" apart around the entire tread! I guess you'd have less wear if you raised the roller off the tire on every start, your tread would last longer.
Another problem is that this engine has a VERY narrow power band. While riding up steep hills, your engine rpm will drop down to a crawl, even with a 1.25" friction roller. This engine works VERY well with NuVinci hub or shift kit. However, with the shift kit, the engine devours 8-speed bicycle chains and low rpm clutch springs. I run a 460 engine frame-mounted with shift kit. It is very fast but very undependable. My friend runs a 460 with Staton gearbox and NuVinci hub. His thicker chain is very strong, but his engine also eats clutch springs.
Good luck. This engine is very powerful and will propel your bike past 40mph QUICKLY. However, be prepared to maintain it on a daily basis.
I have a 26" Diamondback with original disc brakes. If you ride in bumper-to-bumper traffic like I do, you might need to upgrade to 203mm discs.
My next project is a Diamondback 29er and a Kona 29er. I'll be using another GP460 engine and a Tanaka 47R engine for comparison. I will try to run NuVinci hubs on each 29er bike. That way, I can use stronger bicycle chains.
This is my 460 bike:
http://motoredbikes.com/attachment.php?attachmentid=30075&d=1294959863
Thanks.
The 460 is an EXCELLENT engine for a motorized bike. My pal Rick has his up to 53mph on flat ground.
Once I find a reliable clutch, I'll run my 4.5hp 460 engines. Until then, my 2.8hp Tanaka 47R engine is a good substitute.![]()
ok cool thanks. so there's no putting a full size (415 chain) sprocket on the engine/clutch and running it back to a 56tooth left side sprocket like the HT kits? is that what you meant with the 72 tooth? and still out of the envelope?...Sure, the 460 will fit center-framed. You could adapt a universal mount or fab one up yourself.
You will NOT be able to run directly to the left rear sprocket without a jackshaft and extra sprockets. The smallest engine sprocket is 8mm 6-tooth. The largest available 8mm rear wheel sprocket is 72t, yielding 12:1. You need at least 18:1 to use the 460.
A good alternative is to bolt the 5:1 pocket bike gearbox onto the 460. Then you'll need a jackshaft and 3.6:1 more gearing, at the least. If you ran a shift kit, a jackshaft would be needed to bring the chain line inward. If you installed a left rear sprocket, the jackshaft would be needed to transmit the power to the left side.
If you ran a 10-tooth engine sprocket and a 56t 415 sprocket, you'd get 5.6:1.
The bike would not move from a standing start, and no power at all speeds.
