Cranbrook brake question
Discussion in 'Motorized Cruiser Bicycles' started by bc2013, May 6, 2010.
  1. bc2013
    bc2013 New Member
    Dec 8, 2009
    I have a Cranbrook and the rear wheel is loose. When I apply the brakes (pedal backwards) the wheel is tight. When I got to ride it and pedal forewards the wheel is "loose". Would anyone know what the problem would be and how to fix it. Thanks for your time.
  2. sphilsaw1
    sphilsaw1 New Member
    Jun 18, 2009
    35
    there are brake shoes inside a coaster brake when pedal backwards and put pressure on the inside of the hub that makes the wheel feel tight. just loosen up one of the rear wheel nuts and tighten the nut on the inside of the rear drop out until u start to feel the axle tighten up then tighten the wheel nut back and see if the wheel has no play in it. that will be a quick fix to see if it was just a loose wheel.
  3. bc2013
    bc2013 New Member
    Dec 8, 2009
    Thanks for the quick response. I tried it and it seemed to work. I tightened it all the way, but not sure if i'm supposed to tighten it that tight. So I loosened it up a bit so that the "arm" that comes off the wheel and fastens to the frame will rotate freely and that brought me back to my same dilemma. Not sure if that's right or if I should tighten it all the way really tight. Thanks again.
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    You need to make it just tight enough that there is no freeplay. Not "tight". It's a very tricky adjustment, but can be done with a few tries. Best bet is to get a set of cone wrenches, which makes things 100% easier.
  5. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,886
    19
    I had the same problem with a Cranbrook.
    As mentioned there are two nuts on each inside, one to tighten up the hub, the other to lock it in place.
    It takes two wrenches.
    Break the two nuts apart, snug up the inside one, hold it in place and torque the other nut to it.
    If it is either always too tight or it has slop, you may have toasted the bearings riding it loose for too long.
  6. flybytaco
    flybytaco Metal Molding Madman
    Oct 17, 2009
    1,176
    not to be a wise cracker but i have a cranbrook too with major wheel issues i recomend ditching it for a worksy wheel thats how to fix it
  7. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Kinda have to agree here but if you have your wheel off don't just tighten up the bearing cones without taking it apart and greasing the bearings with some quality grease or you WILL be replacing the wheel in about 200 or so miles like I did.
  8. bc2013
    bc2013 New Member
    Dec 8, 2009
    Thanks all for your help. I thightened it up and finally got it working. Thanks again.
