rogergendron1
i need to see pictures or have some advice on how to install the rear wheels on the trike axle so the solid axle will not spinn in the tires bearing... i want to see the system you used to drive the rear wheels...
i was going to make this 100 % myself from aluminum tubing extra thick of course and have a solid axle to drive bolth tires and i was thinking to spin the tires off the axle i would make a flange that the hub would bolt to via drilled holes under the spoke holes, the axle would have a bmx free wheel and my pedal drive and a 44t sprocket as the motor drive and a dick break right on the axle for stopping.
or should i use a 3 speed coaster hub on the bike linked back to a solid sprocket on the axle and use a manic mechanic sprocket adapter on the hub for my motor sproket.... that would give me 3 speeds
the cheaper way to do it would be to use the single speed coaster hub i have now on the bike and add a sprocket to it to go to the rear and run a manic adapter for my motor ... the rear axle would be a free wheel so i could pedal to start but no load wile rolling, and a large disk break and caliper mounted right on the solid axle.
it has to be a solid rear axle as this bike is going to be converted to ride in the snow and gearing must be more torque so i am using the stock 44t but going to 20in or 24in tires for the rear.
and help on the conversion would be appretiated
and any pics of your rear axles would be a great help
here is the video of the bike i am converting over for the winter.
http://www.youtube.com/watch?v=aRF2V16ecFk
loading more pics of bike will be up in a little bit..
