Sikk_29
I recently upgraded to an aftermarket high compression head on my Amazon-purchased (Seeutek) 66cc two-stroke engine. I had been having issues maintaining an idle after the bike had been ridden for 10 minutes or so, which I assumed to be head warpage. I removed the cylinder body to replace a failed (split) base gasket, and, after reassembling with new head and copper head gasket, the bike would not start or even fire at any throttle or choke setting. I lapped the head gasket mating surface on the cylinder (several times now) to no avail. The shape of the head's compression chamber prohibits me from doing this to the head. There is an extremely small discrepancy between head and cylinder when placed together; the head can rock back and forth almost imperceptibly, though the head gasket prevents it when placed between.
The bike can be pushed with the clutch engaged, with some effort, and about the same as when it was in running condition. The engine makes a very small squelching sound as the piston moves, though you cannot feel any air movement on the outside of the cylinder. The clutch is not slipping (the drive gear rotates). I can feel quite a bit of pressure when turning over the cylinder with my thumb over the spark plug hole. When attempting to start the bike you can hear the piston compressing air and the bike drags to a stop as if stalling.
I have checked for spark (maybe slightly weak?) and magneto coil passes a visual inspection (though it has gotten wet before; after drying it ran fine). I have also tried the original head, which did not work in exactly the same way. Fuel seems to be getting to chamber, I cleaned the main jet and the float valve and choke are working. I replaced the spark plug to see if a new crush washer would do the trick (it didn't). I need to replace exhaust and base gaskets again, but this shouldn't prevent it from starting at all?
Any advice or speculation appreciated. Bike has never looked better - but doesn't actually run
