clutch rod bearing
Discussion in 'Motorized Bicycle General Discussion' started by and69, May 7, 2014.
  1. and69
    and69 New Member
    Apr 24, 2014
    10
    How do I remove the bearing to replace on a new rod for the clutch on a 2 stroke 48cc engine?
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    If you're talking about the ball bearing that goes in before the bucking bar, a magnet small enough to fit into the bore of the drive sprocket will work. Sometimes that bearing is stuck in grease and needs a little help. It should come out easily.
    If a magnet doesn't drag it out you might try spraying some degreaser into the hole first to loosen things up.
  3. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
  4. and69
    and69 New Member
    Apr 24, 2014
    10
    The crank shaft bearing is what I need removed from the shaft. I have it out of the casing.
  5. maniac57
    Oct 8, 2011
    4,486
    Tap it off gently. Damaging the shaft will make it harder to remove.
    I also use a small two jaw puller for stubborn bearings.
