G gra1972 New Member Jul 8, 2011 #1 hi all i was wondering if there should be any play in the ring where the clutch pads go ,on mine there is a bit of play and im wondering if thats the squealing noise im hearing
G gra1972 New Member Jul 8, 2011 #2 and do i need a special tool to remove the ring gear or is it just the 19mm nut.
GearNut Active Member Jul 8, 2011 #3 In a perfectly assembled clutch, there should be no play, but they all have play in them due to the poor quality control at the factory. Not much you can do to fix it either. Don't try to take the ring gear off of the clutch. You are in for a nightmarish chase of 50+ teeny, tiny little ball bearings. Read up on the clutch for more info: http://motorbicycling.com/f39/clutch-animation-jim-creative-eng-13545.html http://motorbicycling.com/f39/motor-bicycle-clutch-301.html
Al.Fisherman New Member Jul 8, 2011 #4 gra1972 said: and do i need a special tool to remove the ring gear or is it just the 19mm nut. Click to expand... No special tool needed...Check out photo 37 to 47. Chinese HT breakdown pictures by Ron-Becker - Photobucket
G gra1972 New Member Jul 8, 2011 #5 cheers mate thank for that advice and saving me a lot of drama ,much appreciated.
