Charge while riding?
kevinkrg6
Hi everyone.
I want to charge a 12v battery (for lights and horn) while I ride,
so that the length of time the battery lasts is extended.
I figured that a 12v dynamo like this:
Amazon.com: Bike | Bicycle Dynamo Generator 12V 6W: Sports & Outdoors
could somehow be wired into this.
Could it simply work like this?:
I was simply wondering if anyone knew how to wire the dynamo so that it can charge the battery while riding, or could point me in the direction of somewhere that had a wiring diagram.
You can't just hook up the dynamo to a battery, there needs to be a charging circuit inbetween to regulate the power to the batteries. Since it'll be 12v input rather than normal househould voltage you'll need to construct your own also.
That is true if you want a true regulated circuit as needed with modern digital electronics.
For a bare bones basic charging system, all you need is doide.
Light bulbs are not that finicky.
Ah, ok. I am not sure if I still want to do this then. Methinks the dynamos won't charge up the battery that much anyway.....
Sturmey Archer makes a front hub that generates 6V/3A while you're coasting. I'm looking for info on how to add a simple battery to store juice during the daytime ride and use it for LED lights at night? Any DIY sites that explain how to design a simple charging circuit for 4 x "C" rechargeable batteries ought to do the trick...
Okay...so how about a set-up using a 6 volt (new Sturmy Archer) dynamo to power both the lights (led) and a 6 volt horn? Yes, I get that the LEDs take ac and the horn takes dc.
My thought is to split the output from the dynamo. One circuit goes directly to the lights (ac), an the other circuit goes to a 6 volt transformer (wall wart) to produce the necessary dc current for the horn. Then adding either a rechargeable battery or a capacitor to the horn circuit would ensure reliable horn access even at slow speed or stopped. The headlight has a stand light so that doesn 't require the short term power storage.
Sound feasible? Other solutions? The white wire doesn't seem likely to power the horn, but......
Thanks in advance.
LEDs take DC. You can run an LED on AC because an the D in LED stands for diode, which is a type of rectifier. So an LED actually rectifies itself from AC to DC.
Using a wall-wart will not work. A wall-wart is designed to convert 120v down to a lower voltage. If you want to convert AC to DC, have a look at my step by step instructions on how to wire up an ac to cd rectifier. It is intended for white-wire use, but it will work with your dynamo.
DIY Rectifier
I suggest you build that rectifier (or find a similar one), and connect the output from that to your horn, lights, and battery.
Pilotgeek,
Thank you for the advice. I
've made the rectifier you described.
So, now a couple of extra questions.
What would you suggest as a good configuration given the items to be powered (headlight- taillight and a 6 volt moped horn) and the potential power sources ( 6volt hub dynamo and the white wire). ?
Lights and horn off the dynamo? If so, in parallel?
Lights of the dynamo and horn from white wire?
Some other set up?
As I mentioned the lights both have stand lights, but the horn has no reserve power ....which isn't really an issue.
Again, thank you for the help.
Gery
I've tried a few setups, including running a 6V incandescent straight off the white wire. I'm currently chargeing a 6V 4.5A/H SLA battery thru a bridge rectifier made from 4x 40V 1A Shottcky diodes (less voltage drop than ordinary diodes), & running a 6V 26Watt Halogen lamp of it. This gives bulk light. I havent found out how long it lasts but 1/2 night ride & its still very bright. I keep a sanyo 6V 3Watt dynamo & light as backup but havent needed it. I really think the white wire/rectifier/battery is the way to go. Cheers
That may work , just be sure to put a zeiner diode in line so the mag donesnt recognize any of your curcuits as a short or a ground an not let the bike start.
The gnu,
What is the "that" in "that may work"? Pilotgeek's rectifier?
Is it Ivan H's set-up, or one of the options I mentioned using Pilotgeek's rectifier?
Also, where in the line would this diode go?
Thanks
I would not use a combination of white wire and dynamo, because they may interfere. Combining them on the AC side, you would want to put a diode on both the dynamo line and the white wire line. That would already rectify it, but at only half efficiency of both, so it's kinda pointless to use both. The only feasible way to use both would be to use two separate rectifiers for each power source, but they may "fight" with each other.
I would use only the dynamo. It won't effect engine performance, and I'm sure the dynamo is capable of putting out more watts. The only problem with the dynamo is that when you stop, it doesn't produce power, but if you have a battery it doesn't matter.
So Dynamo -> Rectifier -> Battery -> Accessories
You'll want a switch to be able to turn off all the accessories so you don't drain the battery. While I don't *think* the battery should leak through the rectifier circuit at all, it may be safe to put a large diode between the rectifier and positive terminal on the battery. If the battery dies after a few days of not using it, that would likely be the problem.
That meaning I am a bit confused on your exact wireing layout , heres what works for me off the white wire only , zeiner diode , pilotgeeks rectifier , an a 12 v 7.5 amp hr sla batt all light bulbs are led , the battery has only needed charged 1 time an I do a lot of night riding at least 2 or 3 hours on the weekends any other time the bike is moving I have rear running lights, headlamp on low beam an a licence plate lamp on at all times .
the diode goes in line first be sure not to install it backwards they are marked by a small band of color on one end that band shows you that current can not flow from that side , but may flow from the other side
Pilot geek-
Great. That all makes sense.
Do you have an idea of the battery I should use? I understand that horns are amp. thirsty. So, it seems there significant factors:
1. Size & weight ( smaller the beter)
2. amperes ( sufficient for a infrequently used horn)
3. Ability to be effectively charged by a dynamo
Oops...#4 factor----cost$$$
I realize a 6 volt photo battery probably won't work, but how about an RC vehicle battery? Or, do I need to go to a motorcycle battery?
It might be easier to strap a stray cat to the handlebars and pull it's tail when someone pulls out in front of me.
Also, what sized diode? (For the circuit, not the cat.)
Thanks for your continued advice.
Thegnu- thanks for the clarification. I am just beginning to figure this vehicle wiring stuff out, so I get lost fairly easily.
Best, Gery
Well, a 6v battery will work the best. The white wire puts out an average of a little over 6v (you need more voltage than the battery to charge it). An RC car pack may work but it would have to be NiCd or NiMH because a Lithium battery requires special circuit, but NiCd or NiMH like to be fully charged and discharged. They wear out quick if you keep them topped off.
I would recommend a 6v lead-acid lantern battery. They're relatively small and they have high amperage to power a horn or high-intensity lights. It charges well off the white wire or a dynamo. You can find them cheaper than this, but here's an example: UPG Sealed Lead-Acid Battery
You do not need a diode between the white wire/dynamo and the rectifier at all, in fact, that will cut performance/power output in half. Put any diodes AFTER the rectifier, on the DC side. The purpose of the diode I'm recommending is to prevent the battery from discharging into the rectifier circuit (it shouldn't do that anyway, but the capacitors may "leak" a little current.) Other people use a diode directly on the white wire as an inefficient rectifier, for if they don't have a bridge rectifier. All a diode does is make sure current goes only one way, like an electrical check valve. An AC power source has positive half the time, negative the other time. A Diode just blocks the negative, so you only get power half the time. A rectifier "flips" it so you get full power all of the time. Putting a diode between the rectifier and white wire blocks the negative, so the rectifier can't "flip" it. The rectifier is redundant if a diode is used on the white wire.
A good sized diode to use on the battery would be 3-amp. Even though the battery is larger than 3amp, you're only trickle charging from the rectifier, and you won't go over 3amps unless something shorts out. Diodes
I really should make videos or more step-by-step instructions on how to make a complete electrical system. I know it would help a lot of people, as this seems to be a more and more common thing to add to a bike.
Ok, sorry took so long to get back, I've been laid up for few days with the worst flu ever. The backup sanyo bottle dynamo & light r not connected 2 the mag circuit in any way at all, except the earth thru the frame. Cheers
