Chain tensioner
jototojo
Hi people,
From argentina again, hahaha.
The other day i was ridding on my recently build 2 stroke bike when i hear a "clack" sound, and i see that the plastic part of the tensioner that turns around and guides the chain like moves from right and left, only the plastic part, the metal part is welded to the bicycle.
So this makes the chain go to the centre part of the wheel and finally it goes off the sprocket.
Guyyyss, WHAT CAN I DO!!???
HELP pleassse.
Thanks again.
Hello people again, i still cant fix this problem, i think im gonna cut the part i welded so i can move the chain tensioner far from the wheel, what do you think???
Thanks.
Thanks.
Can't you just bend it??
The tensioner needs to 'feed' the chain straight on to the sprocket, or the chain will derail! (so don't move it away from the wheel too much.) ;)
With what??
Do you think i can heat it with something and try to bend it???
I dont know with what can i do that.
I want to see if I understand what is happening here: is your chain-tensioner and guide wheel "in-line" with the chainstay that it is mounted to? - ie. the same chainstay that runs from the wheel hub to the bottom bracket at the seat post? Or did you twist the chain-tensioner's own bracket a little so that the guide wheel runs in line with the drive chain and the rear wheel itself?
The drive chain does not run in the same exact line as the chainstay your tensioner is mounted to.
With what??
I just used a bench vise, channel-locks, a measure of caution, and a pint of sweat.
I approached the proper angle by trial-and-(very little) error.
i managed to do without a tensioner on my 7 speed with good bike shop chain and a half link so for 300 miles and no regrets
And if you can pull that off, that is the best plan by far I think. Those little "chain tensioner/guide wheels" cause almost more trouble than they're worth sometimes. Alas, my chain would slap the chainstay without one, no matter how I futzed around with the engine mount location. So I'm stuck with using one. And I envy you, Adam.
if your chain stay is tapered shim the narrow end with a chunk of rubber so the roller is inline with the chain get a good chain and check your alinement's
Instead of shims it's better to secure the bracket solidly to the chain stay and bend, twist actually, the bracket to get the wheel to align with the chain path. The problem with relying on a rubber shim is that eventually over time it will compress, loosen and there goes your alignment.
yeah when i pulled it a part today the shims had become distorted but with out them I have to place the tensioner mid chainstay. after tweeking it around it runs great but now it vibrates at speed. left the chain guard off and the chain is vibrating a lot on the top run the alignment is good and its a new chain (410 garage door operator chain) am trying to come up with a damper thought about using a rear derailer but have not figured out how to mount it. looked at some other posts and the farm tensioners they are adapting
If the alignment, sprocket concentricity and tension are right, there should be no reason for the chain to "vibrate" unless you have rollers that aren't rolling or a twist/kink in the chain. Look at your rear sprocket closely. Lift the rear wheel and spin it and make sure the sprocket is absolutely centered on the hub with no wobbles or up down movement.
If that sprocket is right on the money and the chain alignment and tension is correct the chain should ride smoothly over the sprockets both front and rear at any speed. It might waver slightly up and down across the slack portion but it shouldn't "vibrate".
Take the master link out, remove the chain and pull it over your finger from one end to the other to make sure it has no binds anywhere in its length. Even one stiff link can cause you to have a rough running chain. Oh, and make sure its lubed correctly.
the chain is new and is garage door operator chain i centered the rear sprocket by checking the teeth during rotation of the rim its less then a 1/16 out of flat. the chain is a good quality and looks to be the same size as the trashed China chain and takes a 410 link. Also i use a chain tool so I do not use a master link but have been splicing chain since the early 80's wonder if that could be the reason? is BMX chain a better quality they look and feel the same but that dose not mean much
oh not sure if it plays into it or not but I was using rubber shims on the tensioner but have removed them the frame I used has a pretty good taper on the stays and this started after i removed the rubber
To be truthful I've never used #410 chain. I know some do and swear by it but I've had good luck with #41, never had an issue with it and never felt the need to experiment otherwise. I use a good quality, Diamnond or Morse industrial #41 and it has served me and many other builders well.
As far as the tensioner bracket goes, We always suggest to make sure it can not loosen or rotate on the chain stay. The taper really shouldn't effect the clamping action but I happen to be a firm believer in securing the bracket by some method that doesn't completely rely on the clamp method. I'll open a can of worms here by mentioning some ways to do that so I won't but I'd suggest you do a little research and read the plethora of information that has been posted here on the pros and cons of the infamous chain tensioner. Just type in 'chain tensioner' in the Google Custom search then sit back and read. Most important; do what works for you, never mind what others say to oppose your ideas.
