CDI inside
Discussion in 'Motorized Bicycle General Discussion' started by Coval_PL, Dec 2, 2009.
  1. Coval_PL
    Coval_PL New Member
    Jul 28, 2009
    57
    Does anybody know what's inside the CDI module? Is there only coil or something else? I consider the making electronic circuit to power the sparc (by CDI). I want to use as less power as is possible, and use the rest for light and horn. Has anobody some ideas?zpt
    #1 Coval_PL, Dec 2, 2009
  2. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    There should be a coil and a capacitor at least (Capacitive Discharge Ignition). I don't know if there is any other electronics but I suspect not.
    zpt
  3. Maxvision
    Maxvision New Member
    Jun 13, 2009
    551
    Just a thought I had reading this...
    From my experience with anything coming from China, they don't make much that comes with anything but the bare minimum than what it takes to do what it needs to. As small as the CDI is, I couldn't imagine you could make one more efficient than it is...
  4. Coval_PL
    Coval_PL New Member
    Jul 28, 2009
    57
    Thanks a lot. So I have to use Sram i-Light front hub installed in my bike as main power source for electric equipment.
  5. saetta
    saetta New Member
    Jul 29, 2008
    156
    For my bicycle lighting a chose the mini generator from Wonderful Creations (Ebay seller) on Ebay. This tiny coil pack mounts on the right side of your magneto and provides one red wire to exit the magneto cover along with the magnetos wires. I combined this with a LED headlight from Boygofast which has its own toggle switch. The mini generator dishes out 6V for the light and it does not draw juice from the motor. I have been using this for two months and have no complaints! Check it out.
  6. 2door
    2door Moderator
    Staff Member
    16,308
    32
    #6 2door, Dec 3, 2009
  7. xlite
    xlite New Member
    Jun 18, 2009
    736
    The ignition box on an HT is not really CDI which would require sensor inputs and 12 supply. I cracked a dead one open couple years ago and it appears to be a simple coil/cap combo with diode to converve back EMF. Very simple and reliable but not as efficient as real ones with timing advance etc..
    IMO it's a mistake to use the white wire for anything but the ignition. They need all the help they can get, I am very curious about the add-on magneto coil mentioned previously.
  8. HseLoMein
    HseLoMein New Member
    Oct 30, 2008
    121
    I have the coil and its great, you get 6v at idle and it goes up with the rpm. Also you can pull 1.5Amps from this little beast
  9. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    I'm very successfully runnin' Norm's http://motorbicycling.com/f23/lights-7306.html?highlight=lights off of nothing but the white wire, both head and taillight actually - but it's true there's not much left over for anything else like blinkers or w/e.
    When the RPM is low, like idling at a stoplight - it does stagger a bit and could stall. This is just 'cause there's almost no output at all from the mag at that speed. Once I'm actually riding, even really slowly there's no difference I can feel, or my GPS for that matter lol
    *shrug* When I first installed them, flippin' the light switch killed the motor dead, but I just took the plug gap in a tuck (as per Norm's instructions) and it's all good. I was runnin' a really large gap to begin with tho lol
    xlite - I'm curious as to why you would think this a "mistake"? It's true it's not a lighting coil, but I see no potential for damage.
  10. xlite
    xlite New Member
    Jun 18, 2009
    736
    I had almost identical experience to yours. Without goosing up the idle screw and knocking the gap down the bike would stall. Harder to start too. Some other locals did not have ignitions as robust as you and I so never got their engines to run at all.
    I doubt there is any potential (pun) for damage but as I keep saying, these motors are marginal at best and need all the help they can get. As your plug wears and fouls it could mean the difference between being stranded and not.
    I find LED headlight with rechargeable aa batteries a perfect solution for night riding. I think these add on magneto coils have potential (pun #2) also.
    #10 xlite, Dec 4, 2009
  11. BarelyAWake
    Jul 21, 2009
    7,209
    I see what yer sayin' fosho... but ofc there's the "off" switch lol - I never even try to start my bike with the lights on.
    cept when I forgets...
    *shrug* I think I know the conclusion here - no tapping off the white wire unless you fully understand the ignition system and it's effect, willing to replace a weak mag, and are prepared to do the basic check-ups and maintenance ya prolly outa be doing anyway. ;)
  12. Coval_PL
    Coval_PL New Member
    Jul 28, 2009
    57
    Ok, thanks for help. I'll leave magneto in original state and use dynamo as main power source. I'm affraid that Maxvision has right, that Chineese manufacturers use as less everything as is possible and necessery to make things working :(
