The manufacturer of my kit (Ebay: LuckyEarlyBird) says it comes with a Catalytic Converter muffler. However after opening mine up it looks nothing like BareyAWakes (See here: http://motorbicycling.com/f13/catalytic-converter-mufflers-15857.html )
Here are a bunch of pictures I took of the muffler. It was fairly easy to take apart, the end cap was the hardest to take off. I just had to remove the bottom nut and then put the end cap in a vice and twist/ pull. To remove the curved piece from the main tube I only had to unscrew the two nuts and pull the tube away from the curved piece.
The muffler on the bike:
The two nuts to remove the main tube on the muffler can be seen on the sides here:
Main tube removed, honeycomb baffle can be seen at the bottom:
This is looking up into the honeycomb baffle (I read someone else describing it as corrugated cardboard, at least I think that's what they were describing lol):
This is the disassembled main tube with the end cap still on. You can see the two boltscoming out of the end that the baffle/ curved tube goes into. At the other end you can see the nut holding the end cap on.
