Thanks for the replies, It keeps the juices flowing and the feet moving forward,
Thanks for the advance notice on greasing the gearbox. I'm not too gear savvy, and would have probably run it like it was if I got this bike going. It looked greased to me. I still have not ruled out jackshafting it and running it on the left, but that would require alot of additional items. I.e. Jackshaft, and then i would have to get a left hand threaded hub, and left hand threaded freewheel. Last time i checked the hub was $109.00 on stanton's website, I'm not too interested in using the rubber 9 bolt sprocket-to-spoke squeeze method. I did this on a previous build i got as a kit on ebay and broke spokes. It seems to me the driving from the hub is the best way to transfer power from the engine to the ground.
Thanks for the compliment on the gearbox. I do not know who the manufacturer is. (I typed "roger box" in google search) and got nothing. If anyone knows who the Mfg is, please let me know. There is no markings on it. I got it from a guy that had this engine and gearbox mounted on a gocart/pedal car that was a father/son project. I checked stanton's website for a "double sprocket" in his sprocket section. I didn't see one and not sure what you are talking about. If you could patch me a link, I would appreciate it.
Thanks for the idea about the freewheel crank that some Ross bicycles had. Did a little research to find out what you were talking about and this is what I came up with:
VINTAGE SHIMANO INTEGER BICYCLE 52/39 FREEWHEEL CRANKS - eBay (item 390181830501 end time Jun-10-10 17:16:59 PDT)
It looks like back in the 70's Ross used this system on some of there bikes. It is called a Shimano Integer FF Freewheel Cranks. Good idea. Looks like the same concept as the Sick Bike Parts Freewheel cranks?
Thanks for the info about the gear ratio conversion tool. Does anyone know what the RPM of this engine is that I should put in the RPM field in the gear ratio conversion chart/tool? It is a Honda Gx31 Four Stroke.
I saw this on YouTube from thescooterguy. I'm not sure if it is in production, but it looks slicker than snot. Same concept as the double single cog RH freewheels, you just get greater range with the pedal cranks.
YouTube - secondary right side drive
I like the looks of it, not sure if it would work for my application though. The Engine drive sprocket looks large. I still am not sure if this is correct. If my gearbox is 6.9 to 1 and if I got a 22tooth freewheel for the rear to drive the engine chain on the 8tooth output gear on the gearbox, then I would get:
6.9 * 22/8 or (2.75) = 19.02 to 1. Would this be sufficient reduction to turn the 26 inch wheel in/ around the 20 to 30 mph range?
I like the idea of the front freewheel cranks because that would allow me to use the derailleur in the rear to have more engine gear range, keep the engines output on the right side, keep the cassette, and use gears to help the motor transfer power to the ground more effectively. With the Sick Bike parts freewheel cranks, I see that they are square taper. Since I have enough pedal clearance with the stock bottom bracket and cranks I have now. Would all I need from Sick Bike Parts be the Cranks, the two Chain Rings, the freewheel adapter, bolts, and a chainring spacer? and i would be good to go? Or in order for the Freewheel Cranks to work do I need the sick bike parts bottombracket/axle to mount the cranks too? Also looking at the pictures on there web site it is hard for me to decipher, Does the engine drive chain drive off of the back chainring that is closest to the bike, or the outer chain ring that is furthest from the bike?
I've got the materials laying around our shop to make a motor mount that would allow me to make a clean mount of the Gx31 inside the frame.
If you could please answer the questions above to keep the feet moving more forward on this motorbicycle, I would appreciate it. The juices are still flowing and I'm starting to see the light at the end of the tunnel, that would give me confidence to start making forward progress by cutting materials and ordering/buying needed parts.
Many thanks to those who have contributed already,
