Can u name this part? grubee skyyhawk 66/80cc engine kit
Buffaloson
So i need to figure out the name of this part and where to buy it. After removing the plate covering the engine sprocket, its a small round stud that pokes out from the middle of the sprocket, and has something to do with connecting the clutch to the engine. My rents moved the bike while i was working on it and it was lost. Any help is appreciated, i searched everywhere online trying to find one, and if i cant find it, my bike will be useless :-||
I'm not sure if anybody sells that part, I would think you could by a metal rod that dia. and cut it to size. Also behind that pin there is a ball bearing that probably rolled out when your bike was moved.
you part 26 and the ball bearing is part 24. maybe you can ask in this forum if anybody has a blown motor you could buy the parts you need to get on the road..trk
clutch rod = L 26.20mm/ dia 7.92mm
clutch ball bearing = dia 7.92
maybe you can make a rod yourself now that you know the size and you probally can find the bearing at a hardware store.
