Yes, but does it match the paint job like my shrink-wrap?![]()
*considers painting bike to match solder*
I'm using a small butaine torch to heat the cable red, but neither types of solder would melt in, they just rolled off.
Kevlarr is correct. The base metal, the part you're trying to apply solder to needs to be at about the same temperature as the melting point of the solder you're using. Too hot it will roll off, too cold it will not stick. I'll repeat, if your cable is stainless steel ordinary lead based solder will not stick to it no matter the temperature. Let me clairify a little here so I don't get arguments. There are many different grades of stainless steel. I don't have any idea what they use for bicycle cables but any stainless is either impossible or difficult to solder depending on the alloy. Yes, you can get a ball of lead solder to hang onto a stainless cable but there will be little to no adhesion. There is virtually no strength in the solder joint. If all you want is to keep the end of the strand tight you can solder or crimp on a short length of 3/32" brass tubingThere ya go, you're getting the cable too hot. Heat a little, touch the solder to the cable, repeat until the solder melts in.
Bairdco,i can't believe there's two pages (so far) dedicated to soldering the end of a clutch cable...
