I can't let it die either. I like a healthy, civil discussion!
			If a particular bike takes 2hp to go 36mph, than it does not matter how you gear it, it will only go 36mph on 2hp. You could gear it to go 50mph. But it does not matter even if you keep it wide open for 5miles, it can't go any faster (unless if you have a tailwind or go downhill). It will take more power to overcome the additional aerodynamic drag in order to achieve a higher speed.so you are saying no matter what sprocket in the back that the bike won't go over 36mph given enough time to reach max speed?
I have advertisements showing 1.6hp all the way up to 5hp. When the stars are aligned right they put out more than 2hp. After 1000 miles I have to say that it has more power than it used to. I now see 21mph cresting the same hills that I used to manage at only 18mph. It might put out 2.5hp. Close enough so that the legality will not be questioned based on excess power. OK - they have about 2hp. If I get pulled over, I would say it has 2hp and goes 30mph on flat ground since that is what the law allows. Close enough.i find this hard to believe. well i find it hard to believe these motors have 2hp like you are saying. i think they are closer to 2.5 like most advertisers say. however if i get pulled over the bike has 1.75hp and a max speed of 25mph. unless i get clocked going more than 25mph.
i also have to say that you can build 2 engines exactly the same and one is gonna make more power than the other one. i learned that when i used to drag race.
so your motor might only have 2 hp, but mine might have 2.5
