Build complete.
Discussion in 'Motorized Bicycle General Discussion' started by MadMaxed, Feb 18, 2015.
  1. MadMaxed
    MadMaxed New Member
    Feb 15, 2015
    117
    So my Motorized bike is now complete. She started right up and man it was awesome. Rode around the block a few times. and then i let it idle for a little bit. I do have a few question. Is the engine supposed to run a little rough during the break in period? and it seems to have a lot of vibration. Im not going into oil mixture but i used a recommended one. and it seems to like it. A little smokey tho. dance1
  2. Semaj
    Semaj Electric Enthusiast
    Dec 11, 2014
    299
    Re: Build complete?
    Were there groups of children Fist pumping? I hear this is the final Sign.
  3. MadMaxed
    MadMaxed New Member
    Feb 15, 2015
    117
    hahaha nah they are all sleeping
  4. Semaj
    Dec 11, 2014
    299
    Ah, that would explain the rough running,
    take it out after they get out of school or something, that aught to sort its self right out ;)
  5. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    many of these engine tend to smooth up some after two or three tanks of gas run through them.
    where did you get your engine?
    The reason I ask is that there are some that are known to be better balanced than others, I have a couple that have horrible vibes because of a badly unbalanced crank, but I have others that are ncomforta ly balanced from low down all the way to max rpm.
    Just be aware that even the well balanced ones will still have some vibes, a single cylinder 2 smoker cant be perfectly balanced to be smooth at all rpms, but some of the newer china girl engines are way better balan ed than swhat we got a couple years ago.
    Did you rejet the carb?
    a of them I have had co.e with a jet thats to big and that causes the engine to 4 stroke which also makes them run rougher.
  6. MadMaxed
    MadMaxed New Member
    Feb 15, 2015
    117
    I got my engine from a chinese company called Amonstar. it only runs rough at low rpms/take off. after that runs pretty well and idles well too. The carb.... is a piece of work all together. i dont like it but, it will do for now. Until i get it fully broken in, i know that it does run and starts up first try with ease. I tried to pedal with out engaging the clutch and there was somed drag. Wouldnt want to get stuck to far away thats for sure. but i will take tools just in case. It has a lot of potential cant wait to break it in and release the inner beauty.
  7. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    Secure your mounts correctly and it should reduce vibrations
  8. mapbike
    Mar 14, 2010
    5,380
    Good deal, if you have the NT carb which is the most common, I an tell you that its an excellent carb for these engines when its jetted right for you set up and mix you're running they're pretty m7ch bullet proof and I've seen 48mph on one of my bikes running the little NT carb.
    Not saying its the best there is available of course, but its the easiest to tune and it give virtually no problems once its set up correctly.
    Best wishes 9n the build and I hope it keep sgetting better and better as you get it run in good.
  9. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Congratulations, Max. It's a good feeling when these little engines finally fire off and pull you along under their own power
    Just a question. You said you're using "the recommended fuel to oil ratio". What does that mean? If you are going by what the kit instructions tell you and using a 16:1 mix I think you'll find the engine will perform better for you if you go down to at least 24:1 or better yet, 32:1.
    The engine will run better, smoother and produce more power the more miles you accrue. We generally suggest 200 to 300 miles before you can expect the best output. I also agree with Map. Your stock, NT carb is as good as you can expect for a stock or even mildly modified engine. Tune it right and it will provide you with everything your engine can give with little to no problems. They are easily tuned and maintained.
    Have fun and ride safe.
    #9 2door, Feb 19, 2015
  10. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Congratz on getting it rideable this quick...
    Yeah, I'll agree with 2door on the oil mix as 16:1 is way too much oil, 24 or 32:1 right from the get go has been proven perfectly safe, then after that you can continue at 32:1, or go to a better ratio if the oil is made to do so, I won't go too far into this because it always leads to way too much drama...
    I gotta agree on the NT carb as well... for what it is, it's a really good "all around" carb that's reliable and it can perform when set up right (jetting and needle hight) for your engine. Very easy to tune and very reliable is it's best attributes, but a stock NT that hasn't even been jetted to match my engine has pushed my bike over 40mph with 225 lb of me on it.
  11. MadMaxed
    MadMaxed New Member
    Feb 15, 2015
    117
    Nice Yeah i started it out 24:1 but like you said i believe ill go with 32:1 and then get 50:1 oil mix. i know for sure now i have it well lubed tho
