Broken engine mount bolt need help asap
Fishoutofwater88
10
Santa ana
One of my front engine mount bolts broke about an eighth of an inch inside the engine mount. I tried using a grabit to get it out but that didn't work and it smoothed out the beginning of the threads on the engine. Can some one please help! Thank you. :-||
DaveC
969
Boise, ID
The other method is to use a Dremel with a cutting wheel to slot the top of the broken stud and use a screw driver to back it out. With the end of the stud broken off in the hole complicate things a bit but it can still be done. It will leave a slot in the case but there's almost no other way. Many will say to get left-hand drills that when you drill the hole in the stud for an easy-out the drills will sometimes grab the stud and back it out. That's never worked for me but YMMV.
txlixard469
72
austin
I had that same problem but mine was on the back mount and I wen to the home deot and got a m6-1.oo x 50 hex cap screw it worked . send me a message let me know how it worked for you
txlixard469
72
austin
wut was it the wires? I glad you got it runnin I was happy wen i got mine runin agian after a month of not rididng good job baadboy
baadboy
90
tulare cal
no was talkin about when i broke my mount stud is what i was refering to the tread on that
on my speedo prob i didnt have motor grounded
