Brand new 80cc has spark won't start!
Why will it not start?
  • Not grounded
    Votes: 0 0.0%
  • Bad fuel air mixure.
    Votes: 0 0.0%
  • Total voters
Mr big
12
Hello all! I just bought a new 80cc motor kit. I put it all together on a beach cruiser with no big problems. After making sure everything was aligned and perfect i started it up fir the first time. Within a minute it started and ran. Ran for less than an hour. Then stalled as i let it idle just for break in period. After that i cannot get it to start. I checked all the wiring and carby. Thought it might be flooding so i bent the flanges in bowl of carby and still will not fire. Other than chinese gremlins i am at a loss. Any help would be great!
Chaz
1,004
69
48
Vancouver, British Columbia
Bad news for you I'm afraid. I think you have overheated your engine by letting it idle for so long. These are air cooled and need to have air flowing over the cooling fins of the cylinder and head. Five minutes idling stationary is not good, ten minutes is worse...
Mr big
12
Also i live in upstate ny and it was about 35° out and i only let it idle for about 5 minutes.
CrazyDan
67
24
8
35
Yucaipa, CA
Believe it or not colder air can make an engine run hotter than warmer air. Cold air has a higher density (more oxygen in a given volume) than warm air and makes the engine run a little lean unless jetting is adjusted... leaner=hotter. Hopefully you didn't cook it... good luck.
  • Like
Reactions: Tyler6357
Mr big
12
Thanks guys. Just tested for spark and not getting any. Put a drill to crank near magneto. Turned drill on and then tested for spark between blue and black wire and also white and black wire. Doing this should i have seen a spark? Anyway i did not.
Tyler6357
1,142
170
Santa Barbara, CA
To test for spark remove spark plug from head, connect spark plug boot to spark plug, hold the threads of the spark plug to the fins of the head to create a ground, crank the engine with clutch engaged, you should see a spark on your spark plug, do it in the shade or you might not be able to see it good.
Mr big
12
I have done this. And no spark. I removed magneto to inspect it and no spark yet. What is the correct wat to put magneto back on? All stock?
Mr big
12
I also would like to know if putting an electric drill to bolt near magneto to crank motor to test it is really that harmful to motor or not? Nit sure how it would harm motor?
Tyler6357
1,142
170
Santa Barbara, CA
I don't know if a drill can really damage anything, if it were to damage anything it would probably be the magnet. Anyway, the magneto should be installed in the 1 o'clock position.
crassius
4,032
155
USA
even with spark plug out, I've had customer strip end of crank with a drill - that nut & threads may be 4.8 like all the other cheap chinese stuff
